Results 1 to 10 of 11
Thread: 4AGE power upgrade
    Senior Member JDM_KING's Avatar
    jake
    West Side
    Default 4AGE power upgrade
    hi iv got a AE86 with a 4age stocker and i was wanting some in put from you guys on what should be my first thing to do to get more power out of the old 4age?????
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    depending on its compression id just buy a cheap sc12 setup off someone who has bought a 4agze and gone turbo.
    bolt on all the s/c gear and away you go.
    thatll be the cheapest and easiest way to get some noticable difference in power
    Veteran slide86's Avatar
    Huw
    Hills
    intake, exhaust, bp98, jdm ecu and timing
    Senior Member Rip it's Avatar
    Jake
    Pending which route you wanted to go ie, Turbo or N/A. Both the above options sum it up without seriously braking the bank!!
    I got nothing.
    jake
    West Side
    i was wanting to keep it N/A but turbos not a bad idea to
    Jake
    You may want to decide which way you want to go?
    I got nothing.
    Veteran slydar's Avatar
    Dimitri
    rebuild
    78's
    Veteran Rice86's Avatar
    Richard
    Liverpool
    not much stuff u can do anyways besides the things ur already thinking off...
    pod+exhaust, timing, lighten up the car
    dose
    Senior Member awang's Avatar
    Zul
    Brunei
    Stone City
    Brunei
    rebuild, later with itbs perhaps, if you want to go for n/a
    just throwing some ideas here
    Veteran ae86's Avatar
    Western Suburbs
    slide86's comment is on the ball
  1. 4age no power at my coil
    By claw in forum Technical - Questions
    Last Post: 7th June 2011, 02:19 PM
  2. 4AGE 16V injector upgrade
    By aus_86 in forum Technical - Questions
    Last Post: 5th April 2011, 12:14 AM
  3. 4age ae71 brake upgrade
    By ke_70_blue in forum Technical - Questions
    Last Post: 11th April 2010, 01:34 PM
  4. How to get power out of your 4age
    By zookieboi in forum Technical - Articles
    Last Post: 26th October 2009, 08:45 AM
  5. What to use for a power upgrade JDM RWD 4age
    By damo46 in forum General Topics (No Technical Questions)
    Last Post: 21st June 2005, 12:18 AM
