Page 14 of 14 FirstFirst ... 4 5 6 7 8 9 10 11 12 13 14
Results 131 to 140 of 140
Thread: Converting a 3sge to RWD
  1. #131
    Senior Member Anthony's Avatar
    Anthony
    only tested with 3sfe townace and sxe10 3sge flywheels. (both rwd from factory). The problem with celica cna mr2 flywheels is the starter is on the other side of the flywheel and the teeth on the ring gear have been cut accordingly. How much of a problem this is remains to be seen.
  2. #132
    User fantapants's Avatar
    Pat
    have you checked these for fit with the altessa mounts ant.... mine is almost out of the car will let you know tomorow
    06/07/2011
  3. #133
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    i just flipped the ring gear around on the flywheel... only issue i had was the diameter of the flywheel in regards to finding a starter motor with the right depth and to suit the big diameter flywheel
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  4. #134
    What is the outer diameter of the townace 3sfe and sxe10 flywheels? I'll compare it with the sw20 one. I am planning on flipping over the ring gear so that the teeth are bevelled the right way for rwd like s14seriesII has done.
    The depth issue doesn't worry me as I can space it out easily just need to get the starter positioned right so that it meshes correctly with the ring gear
  5. #135
    Just answered my own question. I assume that the townace 3sfe flywheel is the same
    The Altezza (SXE10) overall diameter from the ring gear is ~294.6mm, the MR2 (SW20) flywheel is ~305mm. I received confirmation from both Toda and Jun about the difference in size.
  6. #136
    Adz
    whoa! the extension of your clutch slave is stupendous. looks like you need to lengthen the fork pivot out a bit.
  7. #137
    Veteran biggo's Avatar
    Nick
    Noosa
    nah its fine
    theres more than enough room for the throwout to slide on. However if it were more id have to extend the throwout bearing carrier to keep it on the shaft. Thats pretty border line tho.
  8. #138
    Dec 2013
    mina
    cairo
    nasr city
    egypt
    i found a 99 model 3sge out of celica fwd i guess this is gen3
  9. #139
    Veteran Pidgey's Avatar
    Sep 2009
    Ry
    Sunshine Coast
    Unless it is a BEAMS.
    Yes.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Jacobxxx View Post
    I will legitimately drive nude...
  10. #140
    Dec 2013
    mina
    cairo
    nasr city
    egypt
    its not beams
  1. RWD 3sge corolla $2800 ONO PICS
    By gottago in forum Cars for Sale (Toyota Only)
    Last Post: 7th May 2010, 01:10 PM
  2. tarago diff and rwd 3sge stuff
    By old_school_jap1 in forum Car Parts For Sale
    Last Post: 22nd February 2010, 10:16 AM
  3. Gen3 3sge RWD corolla in SYDNEY
    Last Post: 25th October 2009, 11:06 AM
  4. rwd 3sge. What dizzy???
    By egg_83 in forum Technical - Questions
    Last Post: 12th April 2009, 11:24 AM
  5. 3SGE RWD parts
    By 20valve69corona in forum Car Parts For Sale
    Last Post: 10th April 2009, 10:24 AM
