AE86
all the same
hey,
Can anyone provide me with the part number/s for front brake pads to suit a JDM set up? Need some asap so hopefully something the local auto1 etc can get easy enough.
Cheers Bart
AE86
all the same
Noooo.... he's right.
ADM and JDM AE86 Calipers take the same pads.
Prove me wrong - be more constructive with your posting.
You're doing it wrong.
You need to push the piston all the way back, or you're mistaking it for the need to file out any pads to fit JDM rotors in ADM Calipers.
oh my lolagod
Are you serious. Fuuuck. When i was doing it ages ago the pad wouldn't fit...
</idiot>
Man i feel stupid.
mmmmmmmmmmm.....
hmm, I also have heard about people saying that you need to file some clip or something on ADM pads for them to fit in the JDM Calipers. Also I have also heard about some people who are after a cheap brake upgrade would use the JDM rotors which are ventilated in an ADM caliper but could only use pads which were used and not as thick as new, not 100% sure on this but sounds logical.
hey. Just wanting to find out. The listing for my pad is different than what a brake pad shop told me they were.
I was told they are a DB226 but the listing is DB330 or something similar? Ne1 know if they might have changed or did this place stuff up?
I too need some clarification. The pads in there now are stamped with the numbers DB322 where as the part look up tool on the bendix site says DB398. Anyone able to clear this up?
