pics please
hi everyone,
i hoped this day would never come! I'm selling my baby
its a 1984 slanty front ke70, was origionally mustard brownish yellow but now its matt black! and has a list of mods as long as my armso here goes!
engine:
silver top 20v
fully rebuilt less than 2000 km ago
acl race bearings
fully balanced
arias forged pistons with moly race rings (approx 9.0:1 comp)
freshened head
0.8mm metal head gaskit
rex kellway custom steam pipe exhaust mani (work of art!) with external gate port
tial 38mm external gate
hypergear atr28g1 (based on the gt2860rs disco potato)
3 inch full exh from turbo back with 1 straight through muffler and side exit
cold air intake/airbox segrigated where battery used to be( k&n pod filter)
custom cooler piping with progressive smooth pipesize changes and tridon t-bolt clamps
3 inch in and out e-bay frontmount cooler
turbosmart supersonic bov
custom alloy inlet plenum with 4 inch inlet
std quad throttles
440cc or 550cc injectors(i forget) from 2jz i think
microtec ecu with hand controller mounted on dash
bosch coilpacks and top gun leads
more ive forgotten I'm sure
proudly tuned by Anthony Rodrigues @ Maztech of melbourne
228rwkw @ 16psi
cooling system:
custom home designed and made rwd water kit
s-13 turbo radiator
v8 merc trans cooler used as oil cooler mounted ontop of intercooler
remote oil filter kit
twin wrx thermos controlled by microtech
fuel system:
custom surge tank
vl lift pump
bosch 044 high pressure pump
8mm fuel lines
driveline:
std 20v flywheel
cerametalic 4 puck solid centre frictoin plate & 30% upgraded from hd pressure plate
custom made 4age to w series bellhousing
w55 gearbox (noisey but strong)
corona tailshaft
solid gearbox mount (box is really loud as result)
final drive:
r31 skyline diff
standard width
ke mounts welded on
4.11:1 ratio minispool centre
fnt suspension/brakes:
custom coilovers made from
shortened corona struts
pedders coilover sleeves welded on
celica gt4 kyb excel-g inserts
king 65mm id springs @ 8.5kg/mm
peugot sloted rotors
hilux 4 pot calipers
shortened steering arms for silly amounts of lock
corona lca's for around -2 degrees camber
custom adjustable rose jointed caster rods
all new bushes and balljoints
rear:
falcon springs
swaybar from front of e 36 bmw
torana kyb excel G's.
r31 disc brakes
hydraulic handbrake
body:
typical matt black drifter
few dents
bog here and there
overall it looks great if u ask me, but rought if your picky
large flared guards for wheel clearance
front inner guards massaged for clearance
rough hole in bonnet for old wastegate setup
modified wrx front bar (currently not fitted)
bonnet pins
solex locks
half cage (not in anyway approved)
ill let the pictures talk
wheels:
15x8 -4 performance superlites in white X 6
toyo proxes R1R's 195/50/15 fnts
rear 205/50/15s with plenty also
interiour & miscelanious
autobarn bucket driver seat
r32 skyline passenger seat
otherwise stripped(can get rear seats if required)
grex shift knob
small saas steering wheel
4 point harness not fitted
oil temp, oil pressure and boost guages
ive prolly forgotten some shit but thats about it, this is an awesome car and will be sadly missed if it it sold! its an animal and drifts extremely well, also handles really well when driven grip! i will not sell unless i get what i am after for it, its worth much more to me than to just get rid of it cheap! please don't post crap, i don't need to hear negative comments so please only post if your interested or if you have positive comments
car is located in croydon nth or hawthorn depending on when u ask!
pics will be up soon but I'm sure some of you will have seen it at various drift events, i can sms pics right now so msg me if u want pics asap
it is currently registered but will be sold without unless buyer can organise a mega dodgey before it is picked up so it can be transferred before it is driven away by the new owner!
i am looking for offers close to $8500 but feel free to tell me what you would pay unless its insulting!
0402 686 057
thanks tim--------------------------------------------------------------------------------
pics please
pics here
can someone get the pics from toymods cause im not a memeber and dont really wanna become one?? please?
olympic gold keto
also here... sorry for any inconvenience, were heaps up on old forums but all gone now...
This should help... saves all the linking. Good luck with the sale.
looks tough as bro gl with the sale
this thing fuckin hauls!
hows the borgy coping with all that power? :o
planning to convert to hilux diff any time soon or is the borgy strong enough for now?
pretty sure it runs an r31 diff now
