Page 19 of 56 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... LastLast
Results 181 to 190 of 555
Thread: Slide Spec Ae71
  1. #181
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Thanks for all the comments guys! Beau, should be rad to see you out there some time man!
    The rad support had to have the early front welded in, when i had flat lights i just did a dodgy and drilled holes and used some alloy plate behind it... but for the quads i wanted it done right.
    Probably not going to be hitting up tracks for a short time, just trying to save money for the ze... plus one of my mates is getting his 86 all back together for like a month and then pissing off to the uk for like 2 years lol, so wanna get my clutch done and make sure everything is in perfect working order for epic battles.
    Josh ill give you a yell later this week, that would be a great help man!
  2. #182
    Grant
    Gold Coast
    lol ive hit a pretty big wall.....
    When we did the head gasket on the gze we saw that #4 was slightly lower than #1... not good.
    I didnt wanna deal with it but luckily my mate pointed out that its nothing good and i need to suss it out.
    Pulled the sump off last night to reveal that piston #4 just doesnt have a bearing, and has been run like that... so i got a motor with a scarred crank, have to pull the thing appart now and get the crank machined and the bearings redone.
    Started pulling bits off last night with the help of josh, hopefully this problem wont set me back a great deal... but its not exactly helping
  3. #183
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    man that sucks balls!
  4. #184
    Veteran driftke70's Avatar
    Ryan
    Buderim
    yar the secrets trapped within arnt always good
    wheelfriends.wordpress.com
  5. #185
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    kind of lucky it wasnt a bent rod or anything like that
    good luck
  6. #186
    Grant
    Gold Coast
    Yea im glad im not having to do a full rebuild and its just a case of machineing stuff, still a pain though.... at least im getting plenty of practise of pulling a gze apart lol
    Spent the arvo stripping it back down, just gotta find a gear puller so we can get the timing belt gear off
  7. #187
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    wow what happened to that fly wheel in the background of the last pic...
    FTP.
  8. #188
    Nic
    Mt Evelyn
    it has a rag over half of it
  9. #189
    Andrew
    Gold Coast
    its got a rag over it, just needs to be machined been sitting in my garage for about a year so its got surface rust on it
  10. #190
    Grant
    Gold Coast
    lol i was wondering what you were on about clinton
    That second pic does make it look like i have a pacman flywheel
  1. Slide Spec Ae71
    By ke25 racer in forum KE70 / AE71 Owners Forums
    Last Post: 4th October 2008, 01:28 AM
