1992 Aus spec
Black (had respray under 1.5 years ago)
EVO 4 vent in the bonnet
Refreshed engine (approx 120k old) installed 15000ks ago with Group A cams,Performance Springs uprated valve springs, Cometic MHG and ARP Head bolts,ARP Main bolts,3G lifter's and a quick port job on the head,new timing gear,knock sensor, water pump.
Small 16G
EVO VR4 intercooler and piping
Modified EPROM ECU (VR-4-PLAY special) Raised rev limit,Stutterbox,Revised fuel/timing maps,limits removed.
055 AFM with straight intake pipe & K&N filter
550cc injectors
Walbro 255l HP fuel pump
SX fuel filter and SX FPR
6 puck clutch disc with uprated pressure plate
EVO 2 Gearbox
3.909 ratio 4-Bolt Rear Viscous LSD Diff
Tailshaft was built a few years ago with Brand New Mitsubishi carrier brackets.
EVO 9 suspension
Whiteline Strut braces front and rear
Rockford Fosgate CD Player/Stacker/6.5" Splits
Apexi SAFC
Apexi Rev/speed meter
Omori Oil Pressure,VDO Oil Temp, VDO Boost guages
Has good tyres on it.
Looks good as a "stocker" but goes better than one.
Contact mobile number 0415781726
looking for offers arond 7 grand
will email pic to u
