Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: T50 gearbox
  1. #11
    Veteran Skylar's Avatar
    Ken
    First is not straight cut and has a synchro. You can select first at almost any speeds if everything in the gearbox was in good condition. I can select 1st at any speed up to redline in 1st by double-clutching and rev matching.
  2. #12
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    sounds like every decent t50 gearbox ive ever driven. most gearboxes these days wont let you go into 1st unless youre stationary or less than 20km/h. i always double clutch so it always goes in, but this is only when im about to stop do i put it in 1st.
    i dont know why you need 1st gear on such a close ration gearbox like a t50 unless youre starting from stop, so dont worry about it.
  3. #13
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    exactly same as me, a little tight, or if u double clutch it slips in
  4. #14
    Dave
    Western Suburbs
    yeah ur bushes etc are prob the origionals that are worn in from 25 years of being molested, as my gearbox did the same before
    on the other hand does anyone elses t50 feel like 4th and 5th feel like theres almost no difference ? im starting to suspect my jdm t50 has some sort of gearset in it
  5. #15
    Dave
    well in my car at 60km/h, 4th is 2200 rpm, and 5th is 2000. so not alot but enough. i know this cause my spedo is out, so i guage it on rpm..
    4th gear is 1:1, and 5th is 0.861:1 (according to mr bill sherwoods page). so not that much diffference.
    i like 5th gear though, sits at a nice position in the rev range, but can still "pull" up hills a bit.
    - Blaise Pascal
  6. #16
    Senior Member bams_keto's Avatar
    Stephen
    Sutho Shire
    so you sugest a rebuild kit and a oil change should fix the problem.
    what oil is every one using?
  7. #17
    Dave
    Western Suburbs
    fix what problem ? it didnt fix it caused me to think my gearbox was stuffed lol but everyones seems to be the same
  8. #18
    Veteran corknose's Avatar
    Callum
    i know the noise your talking about i have it to, i can get mine into first most the time without double clutching but some times i have to.
  9. #19
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Every T50 I've ever driven on whines when you downshift into first. In fact just about every older car I've driven does it too.
    As far as I'm concerned rarely is there even a reason to actually downshift at all into first. And if you're coming into a stop, just put it into neutral or keep the clutch down. Then when you're ready to take off put it into gear.
    Seems to me this is just one big non-issue.
  10. #20
    Dave
    Western Suburbs
    yeah i was just worried cause i never noticed the noise before i put the new shifter rebuild kit in cos it would just slip in 1st i never thought i had any issue, since its common im not fussed aslong as it lives its life as i take care of stuff
  1. Replies: 12
    Last Post: 11th October 2012, 12:42 AM
  2. CA Gearbox, T50 Gearbox, Ecu's,Exhaust QLD
    By damien454 in forum Car Parts For Sale
    Last Post: 23rd July 2012, 01:02 AM
  3. T50 Gearbox
    By Andyy in forum Cars or Parts Wanted
    Last Post: 26th March 2010, 08:56 PM
  4. T50 gearbox
    By wideslider in forum Car Parts For Sale
    Last Post: 25th October 2007, 06:05 PM
  5. t50 gearbox
    By sanchez in forum Cars or Parts Wanted
    Last Post: 15th August 2007, 04:15 PM
