Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 33
Thread: Thoughts and help on this setup?
  1. #21
    Brad
    Central coast
    my thaughts exactly.
    sr expansive and sounds like a truck.
    ca sounds pimmpppp, and are mostly free. just need some new bearings and another oil return haha.
  2. #22
    Veteran Skylar's Avatar
    Ken
    You don't need another oil return, you can just rearrange some hoses.
  3. #23
    Brad
    Central coast
    how does re-arranging hoses get the oil back down to where it belongs?
  4. #24
    honestly just go 4age easy strate forward sounds grate an no fart asing around with custom parts. you will be happiear in the end trust me i tried an engin conversion once got over it with the custom shit and what not so never agen just do what is easiear as you will lurn alot and beable to take that into future ideas.
  5. #25
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i too would like an answer to this question
  6. #26
    Ken
    Create a vaccum in the block and let the cam covers see atmosphere. The oil will follow the air.
  7. #27
    Veteran slide86's Avatar
    Huw
    Hills
    how can you have a vacuum in the block, but a vent to atmosphere in the cam cover?
    if there is a vent in the cam cover, then the entire crankcase will be at atmosphere.....because they are all one space.
  8. #28
    Ken
    Pressure differentials create flow.
    The block is at negative pressure.
    The cam covers are at atmosphere minus a little bit due to pressure drop across the little filters.
    Fluids flows from high pressure to low pressure.
    I'll draw a picture later if you don't get it.
  9. #29
    Gunner
    Where are you going to source this vacuum from?
    Let me guess, the inlet manifold?
    So when you put negative pressure to your block, from your manifold, with your open to atmosphere breathers in the rocker cover, whats going to happen?
    I will bet it will blow smoke like you are injecting oil straight into the chamber at idle. Then when the air you will have drawn through your breathers hits the manifold, it's going to hunt like a bitch.
    Please explain how it would work, without causing these issues?
    And also explain to me how it will work at wide open throttle, with no vacuum, and in this case boost.
  10. #30
    Huw
    Hills
    yeah thats what i was thinking....
    the issues with CA's is that after hard or long rev sessions, all the oil is stuck in the head cause it cant get back to the sump quick enough....causing lack of oiling issues.
    so your idea is a bit null and void cause extensive revving = lots of boost, not vacuum. this is where the extra drain on the back of the head come into play ie smallport 4age.
  1. thoughts on new holden colorado
    By s13 james in forum General Topics (No Technical Questions)
    Last Post: 20th September 2012, 09:15 PM
  2. Thoughts on a 13b 86
    By Fallen Angel in forum General Topics (No Technical Questions)
    Last Post: 7th November 2011, 02:30 PM
  3. Next car, thoughts?
    By Jimmee1990 in forum General Topics (No Technical Questions)
    Last Post: 25th August 2011, 06:11 PM
  4. are my thoughts completely off?
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 4th February 2008, 05:56 PM
  5. Imports and Thoughts
    By Kebin in forum General Topics (No Technical Questions)
    Last Post: 15th April 2006, 10:37 PM
