Car - AE71 Corolla running T series diff, one piece tailshaft
Height - Lowered on cut falcon springs (220mm) custom made shocks to suit.
Problem - Concerned about pinion angle, angle isnt too bad as its not THAT low, but would like to look into possibilities of correcting it.
occurs/started when - When i lowered the car and bolted a one piece tailshaft in. I have a feeling my uni's arent going to last very long.
Personal situation - After researching adjustable upper trailing arms (whileline) and traction brackets (ajps, whiteline) i've thought about the possibility of using upper trailing arms from another vehicle to maybe give the correct pinion angle. I have found out that the Ae95 (4wd) and the tercel also run the same bushes as the Ae71/Ae86, which will allow an easy bolt in. Has anyone done anything like this before? or know the lengths of the trailing arms from the vehicles mentioned?
