some s13 and r32 are 15/16 some are 7/8
the 15/16 is a 'bm44', the 7/8 is a 'bm38'
these model numbers are cast on the master cyl' body and is what you need to be using to identify them
i have both here but im using the bm44 on my car with gtr brakes front and rear
a friend has the fd brake setup and a bm38 but is having problems with a low and spongy brake pedal
remember when using these nissan masters that you must do away with the stock proportioning valve and sometimes mod the nissan one so that the system is relying on the aftermarket one you have installed which is the same as mine
the stock brake lines can be moved about and changed around to fit the nissan masters perfectly
