Sounds like you have a nice shell to build so why not eh.
I suggest you find a halfcut. Maybe Buddy Parts or the other sponsors will have what you need. It may be hard to find but you will get all the bits you need and can sell what you dont. Its probably the best way to get an air con system, motor, wiring, ecu, the lot. You also get a few nice jdm items to add as well. You will even get a jdm t50 with the slave on the right side. Itll be worth it in the end.
Other wise, look for someone doing a part out and make sure you find out the credentials of the motor.
