Results 1 to 10 of 11
Thread: Crappy brake pedal feel
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default Crappy brake pedal feel
    Trying to get my pedal to bleed up firm, but it just remains spongy.
    running standard JDM brakes with QFM pads and brembo fluid.
    pretty sure there is no more air bubbles in the lines and i have just put a brand new master cylinder in.
    Any ideas?
    the only thing i can think of is if there is a difference between ADM and JDM master cyls/boosters as it has an ADM one in there now.
    Andy
    Andy
    Adelaide Hills
    rubber lines, original calipers
    master brace would probably help, but i don't think it would cure the problem.
    they are soft all the time, and i think the original calipers may be some of the cause of the problem, you can see them flexing when you push the pedal hard
    Andy
    Andy
    Adelaide Hills
    i should add that they used to be alot firmer before i replaced the master cyl
    Andy
    Veteran Konakid's Avatar
    Henry
    Eastern
    bench bleed the master cylinder again
    Andy
    Adelaide Hills
    bench bleed? as in disconnect the lines and bleed it directly from the cylinder?
    Andy
    Site Supporter Javal's Avatar
    Josho
    Yes.
    Also, does the pedal get hard when you pump it up?
    Veteran MINIHORSE's Avatar
    Felix
    Inglewood
    i couldnt resist
    West
    The master cylinder bleeding is the go, did that fix it?
    Veteran slide86's Avatar
    Huw
    Hills
    oh man
    javal, kona and myself spent 2 hours at the metro love factory trying to get the brakes good on the corona wags....
    turned out that there was some air in the rears and i had to undo the calipers and hold them horizontal whilst bleeding them cause there was air trapped in there on a werid angle.
    bench bleeding the master is definetly the way to start......
    make sure that you cover the ports with your fingers as you let the piston out, this will suck the fluid in properly.
    Andy
    Adelaide Hills
    yes it does improve, but not what i would call a good brake pedal.
    Andy
  1. loss of brake pedal after drift
    By Bozu in forum Technical - Questions
    Last Post: 16th August 2011, 11:49 PM
  2. brake pedal slowly away when braking
    Last Post: 22nd November 2010, 10:23 PM
  3. Brake pedal to the floor
    By Adsie in forum Technical - Questions
    Last Post: 4th March 2010, 10:58 PM
  4. Soft Brake Pedal - Urgent
    By bigm in forum Technical - Questions
    Last Post: 12th June 2009, 09:37 PM
  5. Brake/clutch pedal box
    By Blackers in forum Technical - Questions
    Last Post: 23rd August 2007, 02:14 PM
