Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: cusco formula link
    Veteran johl's Avatar
    Johl
    Default cusco formula link
    been doing a bit of research and there is very little info on formula link front ends. alot of websites seem to list it as trailing arms aswell as the castor rod control arm setup.
    anywho i was just wondering what people who have actuallly used them think about them?
    Gone
    Joel
    Picton
    They are the ducks nuts, the advantage this setup has is that it allows the castor rod to pivot under load, and when castor is added the arm has a free point to pivot on instead of being fixed. if u can afford BUY it! but you are looking at around $1600 - $1700 landed.
    AJPS can get them for you.
    Johl
    nah i can get them cheaper than that.... but yeh i was gunna just go rose jointed everything but i may aswell get the formula link
    Johl
    I just wanted some first hand reports to see if they are that much better than a normal rose jointed setup. And i'v only seen buddy parts use one in his ke 70.
    todd
    ken from infinite uses them too in his ae86
    Jon
    Durack
    i want to 4 link the AE86 anyone got pics and setup tips?
    and pros and cons of rose jointed /vus cusco and so on
    Moderator Frak's Avatar
    Jamie
    I have Cusco lower arm(full fab, not modded standard) and caster rods in the front, equal length rear, handling is very precise
    Hachiroku since 1994
    Go Fish
    be warned, if you go rose-jointed 5 link in the rear, then you better start buying every pair of axles you can find
    Ken
    Spearwood
    LOL. WTF
    What part of having rose-jointed links and panhard rod make axles snap?
    Senior Member ROLL3R's Avatar
    Intense force on the diff while cornering as the diff cant flex in its mounts at all with rose joints. It will more likely snap the welds on the mounts or chassis before it snaps axles.
    " I swear its stock officer. Just don't get me to park next to another Ke70 "
  1. Formula Atlantic
    By timbo in forum General Topics (No Technical Questions)
    Last Post: 17th January 2012, 03:12 PM
  2. Unusual Watts link design + general watts link discussion.
    By slide86 in forum Technical - Questions
    Last Post: 14th July 2011, 06:58 PM
  3. Formula 1 2010
    By breno in forum Grip and Tarmac Racing Section
    Last Post: 24th August 2010, 02:16 PM
  4. Cusco Formula link LCA + tension rod
    By sundee in forum Technical - Questions
    Last Post: 10th June 2009, 06:40 PM
