Results 1 to 10 of 12
Thread: SR20 bits...
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default SR20 bits...
    Sr20 fully ported head.. Stainless oversized valves. Ti retainers, heavy springs, Solid lifters. 314 13.? mm lift JWT cams.. Was rebuilt last time it went onto the engine so new valve grind and guides.. Will need to have all the rocker shimms redone as a few fell out whilst getting moved and could have been mixed up.
    Allso, This is a front wheel drive head, not a direct bolt on but I have a custom alloy front pulley setup for a crank trigger system and you even get my old Microtech Lt8 ECU to go with it... $1700..
    Ally flywheel and puck clutch to suit SR... $300.
    Horsepowerinabox. If you want to see what they look like..
    SR20det JE forgies... 8.5:1 compression.. Brand new still in the box.. 86.5mm bore. $650
    SR20 eagle rods.. near new only done a few hours work IF THAT.. $350
    Sr20VE pistons.. drop in factory piston that raises compression to 11.5:1 in stock sr20 $150
    Sr20 quad throttle intake... This is the EFI hardware kit... Originally cost me over $1200. Has had a lot of hand finishing. Custom truphets. $700
    Pair of wings tree piece 15x6 wheels.. $50. (they're welded, so no flippage)
    All parts Brisbane northside.
    Local pickup on most items..
    0416 434 691.. Jason.
ID:	6122   Click image for larger version.
ID:	6123   Click image for larger version.
ID:	6126   Click image for larger version.
    Hey mate pritty keen on the flywheel and clutch and the det forgies.. pm me
    Cheers James,
    Oh just a question "do u have a SR20det 5speed box"
    Cheers James,
    Jason
    Nundah
    Yeah.. I do.. but i'd like to keep it as a spare..
    Senior Member bams_keto's Avatar
    Stephen
    Sutho Shire
    Sr20 quad throttle intake... This is the EFI hardware kit... Originally cost me over $1200. Has had a lot of hand finishing. Custom truphets. $800
    pics please! is it for a s13 or s14/15 motor?
    Jason
    Nundah
    As far as I'm aware you can only get the Quad intake for the S13 engine...
    Not unlees they've developed a new new kit recently...
    S13 head flows more anyways so It seems sorta pointless to bother with an s14 head.. Only advantage it the VTC..
    I'll try and grab a pic for you soon bud..
    Jason
    Nundah
    Pics up... Can get pics of other stuff if anyones is intrested..
    Craig
    Nsw
    Castle hill
    hey mate pm sent
    cheers craig
    Jason
    Nundah
    Bump.
    Jason
    Nundah
    Bump..
  1. sr20 bits,ke70 bits, cambertops,coilover kit
    By thr55t in forum Car Parts For Sale
    Last Post: 28th March 2012, 05:31 PM
  2. Trueno Bits - Powdercoated bits - KE70 conversion bits. - Brissy
    By LittleRedSpirit in forum Car Parts For Sale
    Last Post: 7th March 2011, 06:07 PM
  3. Replies: 0
    Last Post: 13th August 2010, 12:32 AM
  4. Setup ae86 with sr20 or s13 with sr20
    By MR 86 in forum Technical - Questions
    Last Post: 5th July 2010, 11:56 AM
  5. sr20 bits and other stuff
    By fatke in forum Car Parts For Sale
    Last Post: 14th June 2009, 08:14 PM
