I need the plastic/metal clips that hold the metal trim panels around the outside of the rear 1/4 windows on an AE86
i need most of a full set. there are 3 different clips around the edge. each clip is held down with 1 screw
if you take them off, please look carefully to make sure the plastic tabs on them that hold the trim panels, are not broken off.
cash waiting, thanks
