Power-fc is plug in option. You need whatever the car orignally had. A 4A-GE one will require you to go back to single coil.
AW11 GZE are 4 wire CAS right? If so, you might be able to run 3sgte pfc from sw20 or st1205 but will require you to run the same ignition setup it originally had. You can run COP with a 222 or 202 bosch ignitor if you want to do COP or stick with dual output coils.
You will need a AIT/MAT when you go back to MAP too.
