Results 1 to 10 of 13
Thread: drilling sheared bolts??!!
    Default drilling sheared bolts??!!
    just sheared an oil temperature sensor in my new omori oil setup..
    will drilling it out be my best option or does anyone know of a "tool" for this kind of problem..??
    cheers.
    Dave
    one of those reverse screw things might do the trick. "easy out" i belive they are called. ive had success with them once.
    how big is it? oil temp sensor woudl be fairly large right? how did you snap it?
    how tight is it in there?
    and how deep is it?
    if you can get access to it, you might be able to put the item in a vice, and slowly tap the bolt on the edge. spinning it out bit by bit. use something sharp and a small hammer.
    - Blaise Pascal
    Darren
    try left hand drill bits an if that doesnt get it out, then try easy out it, an if that doent work crc it overnight, then retry!! Get it all the time on machines at work, an you will surprise yourself with what you can get out
    great!! thanks alot!!
    the sensor is not that large.. like a 3/8 diameter brass bolt, but its hollow down the middle and the top sheared off so no chance of hitting it out witha screwdriver but the easy out option sounds the go!!
    Timmy D
    North
    if its got a hole already easy out will be real easy.
    BUT first like dave said get a centre punch on one side of the snaped sensor and tap it so you have a nice centre pop "dimple" now angle the centre punch 45 deg and lightly tap in a anti clockwise direction and try and undo the sensor. most of the time my easy outs dont leave the tool box because this little trick works. that said its not a bad idea to go buy some easy outs like the saying goes
    he who dies with the most tools wins!
    JJ
    I usually just hacksaw a cut down the middle and screw it out with a flat blade if that helps..
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Grab an old Torx bit which is slightly larger than the existing hole and tap that in first, then screw it out with that. If that doesnt work then use an easy out, if not the easy out then redrill and tap it.
    Here is something i wrote up a while ago:
    Senior Member Stain's Avatar
    Derek
    Far North
    I used an easyout when i snapped a camshaft cap bolt... I tell ya, that wasnt fun.
    Had to be really careful getting it out... being such a small bolt/hole and being so close to the cam and valves!
    Got the bitch tho.
    Default Got it!!!
    WOW what a mission.. thanks for all your help.. i merged alot of the ideas and built a hybrid solution
    ended up cutting a square hole into the brass and using a square ended screw driver with opposing vice grips on the handle wings as leverage..
    check out the twist on the solid screw driver shaft!! it was SOO ridiculously tight.. my bad..
    well the guages are in and everything works!! WIN!!
    thanks again
    Senior Member Ae86sam's Avatar
    Manly
    I call Thread king.. Cost like $40 or something and took him about 2 minutes.. was painful to watch though.. he made it look way too easy..
  1. Re-drilling Castor Arm into LCA?
    By Hazzard in forum Technical - Questions
    Last Post: 25th January 2012, 01:46 AM
  2. re-drilling rotors
    By MR86ER in forum Technical - Questions
    Last Post: 21st February 2011, 07:48 PM
  3. Wheel Re-drilling in melbourne?
    By keiichi in forum Melbourne & Vic Events and Discussion
    Last Post: 21st October 2009, 11:00 PM
  4. Wheel Re-Drilling
    By gumbie in forum Brisbane & QLD Events and Discussion
    Last Post: 10th May 2009, 03:47 PM
