Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: oil change frequency?
    Timmy D
    North
    Default oil change frequency?
    Hey guys im running a 4agze in a daily, i did a oil change last night and tried out some motul oil with a drift filter. now this cost me 80 bucks 60 oil 20 for the filter.
    now everyone always tells me "change your oil every 5000 km"
    when i bought the motul oil mr man from the store said "oh yes this is a much better oil so you will only have to change it every 10-15,000"
    this got me thinking, the mentalitly to change oil every 5000 is this a old school way of thinking? are our oils being made better these days and standing up to the task allot better than when eveyone was driving around in 253 powered holdens?
    my can is a driven every day its not uncommen to rack up 400-500 km a week, instead of changing every 5000km could i stretch it out to 7 or maybe 10,000? save a bit of cash and time
    what do you do? and what are your thought on newer oils lasting longer?
    discuss
    JJ
    Dave
    i still do 5000km oil changes
    but i don't buy that expensive oil. i just buy penrite hpr15, which is like $40 for 5L. which i think is still pretty good stuff, compared to that of the stuff you find in coles.
    theres alot of talk of how long oil lasts, new being better than old. which to a certain extent is prolly true.
    but unless you have the proper equipment to determine when the oil is "stuffed" then there is really no way of knowing. so i just change it at 5000km just to be on the safe side.
    luckily for me that only comes up about twice a year, but for you thats could be every few months.
    also depends on how hard you drive, my dad only changes his and mums oils every 10,000. but thats in a hilux and a 95 corolla. and i dont think the engine sees more than 30% throttle....ever.....and they change gears at like 2,000 rpm every time.
    however im assuming a 4agze would get a bit more of a pounding (so it should!!)
    - Blaise Pascal
    Veteran Rice86's Avatar
    Richard
    Liverpool
    do what you wish
    but i try to do it every 5k, just so i know my engine can stay as clean as possible and such blah blah blah
    im not sure about new oils being able to do the job better and longer, i would still do an engine oil change every 5k cause in the long run i know it shouldnt stuff up on me...and if it does then it was bound to stuff up sooner or later... in other words
    proventing an issue before they actually occour
    its a daily drive but im going to asume you do some spirited driving with it too?..
    dose
    change oil every 3k kms. Use hpr 10 penrite semi synthetic.
    Change oil filter every second oil change only use genuine toyota filter.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    $80 isn't really that much for 5000km's.
    Suck it up and pay the price.
    Moderator Frak's Avatar
    Jamie
    I change my oil every 3000km, Royal Purple 10W-40 and K&N oil filter.
    Hachiroku since 1994
    Veteran Skylar's Avatar
    Ken
    Tell me where you got that oil filter!!!!
    Jamie
    Do you mean the K&N??? I live in Adelaide, get them from Outlaw speed shop p/n 1003.
    Site Supporter Javal's Avatar
    Josho
    Clearly TAFE pays the mega-dollars
    I change mine every 5000, using a quality name brand oil. I would never increase my oil change interval regardless of what oil i'm using.
    Ken
    Thanks dude.
  1. Oil change -> Oil leak problem
    By Driftspec in forum Technical - Questions
    Last Post: 26th November 2009, 04:12 PM
  2. how to do an oil change......with hot semi naked chicks....
    By slide86 in forum Toyotas in the Media
    Last Post: 4th August 2008, 11:28 PM
  3. HELP Needed! 4ac Gone weird after oil change ?
    By li21 in forum Technical - Questions
    Last Post: 1st October 2007, 09:27 AM
  4. diesel in your oil change
    By damo46 in forum Technical - Questions
    Last Post: 14th January 2006, 12:48 AM
