this seems to happen quite a lot for me....but in my case its always the bulbs that go...high beam works but normal doesnt...
i say try different bulbs even if those ones seem ok, just to make sure it isnt the bulbs
Car - 1985 Levin
motor - 4ae
use - building car up for daily/ possibly learn to drift
problem - my head lights do not turn on, They go high beams, but no normal headlights, Parkers come on, have checked fuse and replaced it, no luck, both bulbs are fine no filaments have been damaged
occurs/started when - at night time when i need to see things
personal situation - i cant drive at night
dose
Its the switch, take it out and give it a clean with some electrical cleaner. If you cbf doing that Just hit the switch with your palm and that should turn the head lights on. Ive got the same problem with my headlights as well
also here is a thread on club4ag about how to take the dash cluster apart.
thanks guys will give that a shot right now
If you have your switch out, resolder all the connections on the internal circuit board. Dry joints on it often cause problems.
