Look up wheel repair places in the yellow pages. Take your wheel to one of them and ask.
My guess is that is a bit too serious to weld and roll straight, but I am no expert, and alot depends on the alloy used (how brittle etc).
wheels -Performance wheels challenger Alloy Cast?
size - 15x7 +8
use -Drift rims
problem -cracked and little bent.
occurs/started when - once car rolled.
personal situation -need to get them welded is it posible ?Would it be much ?
Yes repairable... I have repaired rims that have been gutter bashed so hard like 4 inches of the outer section was broken off..
If you get quoted over $80 tell em to get stuffed... Seriously would take about 30mins to fix that rim.. at the most.. With out machining..
mad should be sweet as cheers guys .
Were in sa does it ?
