Results 1 to 7 of 7
Thread: speedo needle bouncing
    Senior Member BLIPAE86's Avatar
    Daniel
    qld
    The Switch
    Default speedo needle bouncing
    speedo needle bouncing when moving any ideas on how to fix and were to start looking
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Pull the cable out clean it and regrease, start at the elbow out of the gearbox though.
    Tan
    West
    Or the other way around, pull the cluster off and drive around watching the cable spin round-round...maybe not such a good idea, as you should be watching the road
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Deal with it perhaps.
    You have to realise that you're dealing with 25+ yo cars. You can grease things as much as you like, but half the time the gears associated with the speedo are too warn fix.
    Aaron
    instead of dealing with it you could try the first recommendation.
    like golberg said half the time stuff is worn. but the other half the time you can actually fix things but with a little time and effort.
    remember just cause a car is 25yo doesnt mean it isnt repairable. otherwise every answer to a tech question should be "its 25 yo deal with it"
    also a little bit of grease on the gears in the cluster is helpful.
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    i just deal with it.
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    same, i havethe same problem at arund 50kmph but i just deal with it.
    bursting ovaries since 92'
  1. ae86: bouncing speedo issue
    Last Post: 19th April 2011, 07:00 PM
  2. Replies: 11
    Last Post: 30th January 2011, 03:56 PM
  3. tacho needle interference
    By pen15 in forum Technical - Questions
    Last Post: 26th June 2010, 08:48 PM
  4. help with my speedo
    By deanoo in forum Technical - Questions
    Last Post: 23rd July 2007, 09:52 PM
  5. Speedo
    By damo46 in forum Technical - Questions
    Last Post: 17th November 2005, 05:24 PM
