Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Critique my ignition map?
    Jun 2009
    Grant
    California
    San Jose
    USA
    Sorry but my MSQ won't work for you. I'm using VEMS, the .ini files are completely different. We're just using Megatune for older firmwares, the VEMS guys are working on their own software called Vemstune.
    Well, I stumbled across some thread that said that Taka Aono, a well known AE86 enthusiast here in California (also competing in Formula D with a Turboe's Formula Atlantic motor!), went up to 40 degrees of advance at higher rpm, full load! Anyways, I bumped timing up to 35 degrees and the car feels noticeably stronger!
    OK, major question:
    Does anyone know why the timing drops off as revs increase? I read about belt slack causing timing to retard when using the OEM CAS on a 20V, and I seemed to notice it...by about 4500 rpm, my timing gun was showing that I lost about 5 degrees of timing! Maybe that's why my car responded well when I bumped up the timing a fair amount.
    Can anyone help explain what causes this phenomenon? That should mean cam timing changes by that much as well, right??
    Coolangatta
    If you don't mind sending it through I just wanted to have a look at the settings you've used to compare them against my current set up. I've currently got my timing running up to a smidge over 35 degrees.
    Sorry, but can't help with your question. I'd be interested to know though!
    Jun 2009
    Grant
    California
    San Jose
    USA
    OK, I think I heard ping at higher rpm, and it seemed like the power dropped off at above 7K. I had 37 deg. of advance, assuming the belt lag would pull 5 degrees from the number. Regardless it was too much.
    I'll send the file tomorrow.
  1. Ignition wirse, help?
    By tc-rolla in forum Technical - Questions
    Last Post: 25th March 2010, 08:10 PM
  2. C.D.I. Ignition
    By slideways in forum Technical - Questions
    Last Post: 5th October 2009, 05:26 PM
  3. Ignition Timeing
    By grape_moosha in forum Technical - Questions
    Last Post: 26th March 2008, 09:32 PM
  4. ae82 ignition
    By ae71 in forum Technical - Questions
    Last Post: 29th August 2007, 03:26 PM
  5. Ignition Barrel.
    By dish in forum Technical - Questions
    Last Post: 15th April 2006, 09:04 PM
