Results 1 to 10 of 15
Thread: 4age bigport ( injectors replacement )
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default 4age bigport ( injectors replacement )
    hey guys was wondering what injectors i can move to for a standard bigport, my injectors are a bit noisy so i want to change over to something, prefrably if im able to get something newer id be happy with that so just seeing what others have changed to before i jump on the bandwagon
    Dave
    if you change the injectors to ANYTHING except stock then you need an aftermarket ecu to control them.
    there are many injectors that "FIT" but if you just plug them in they will be different sizes and thus wont work properly with standard ecu.
    if you think yours are stuffed then pick up some new ones (i have some if you want to buy them) then take them to an injector cleaning service where they will run them through their awesome machine, and change all the seals. you will then have a brand new set of injectors to use.
    btw all injectors tick....its when they dont tick you have to worry.
    - Blaise Pascal
    Dave
    Western Suburbs
    thought maybe smallport ones might work to a slight difference or something withoute having to go aftermarket all good thanks for reply, il get in contact if i get more money soon
    Ok
    Seamus
    Milton
    LOL
    what exactly do you smoke that makes you worry about injector ticking noises? i mean .. if you can hear that shit over your exhaust something's wrong. or you're a dog in a human body?
    Injectors usually make some noise. If anything take them out and have them cleaned and flow tested. Small port are like 210cc each over the 182cc that bigport is. You will be over fueling like crazy plus the plugs are different. (could be wrong aobut injector sizes, been a while since i looked into it)
    Clean and flow test would be best.
    Dave
    Western Suburbs
    ta, well yeah i can hear them over my exhaust when idleing (fairly sure and hopeing its injectors) and my exhaust is trd copy extractors with 2.25 catback its not really silent either, so indicates how much ticking noise there is, btw thats with hood closed.
    Dave
    Western Suburbs
    just had a listen then, sounds like the most vibration / noise is @ bottom of injectors
    judgeing by the way seamus told me to have a listen ( screwdriver to the ear )
    Elite rthy's Avatar
    Leo
    Tulla
    lifters maybe?
    Ok
    Seamus
    Milton
    i mentioned he *might* need a valve adjustment, especially if he can hear the noise clearly over his (supposedly loud) exhaust
    Moderator Frak's Avatar
    Jamie
    I second this
    Hachiroku since 1994
  1. 4AGE bigport injectors ADL
    By PHAT86 in forum Cars or Parts Wanted
    Last Post: 14th March 2012, 01:52 PM
  2. Wtb: 4Age Bigport Injectors
    By 71rolla in forum Cars or Parts Wanted
    Last Post: 8th August 2011, 12:39 AM
  3. Replies: 0
    Last Post: 2nd May 2010, 04:13 PM
  4. 4age bigport injectors
    By cando1 in forum Car Parts For Sale
    Last Post: 27th January 2009, 01:04 PM
  5. WTB: 4AGE Bigport Injectors
    By MrMatt in forum Cars or Parts Wanted
    Last Post: 22nd September 2008, 06:12 PM
