Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 11 to 20 of 69
Thread: ae86 rear coilovers
  1. #11
    User fantapants's Avatar
    Pat
    thats essentially what the t3 kit does sam.
    to get the car low enough for most of us, the spring perch is basically on the adjuster knob at the bottom. and the hat moves the spring downabout 85 mm from the mount point.
    06/07/2011
  2. #12
    Senior Member kaibeecee's Avatar
    Pete
    it is pretty awesome, rather simple in theory too
    and for most conventional rear coilovers, you have to elongate the mounting hole for them to mount properly without shell interference.
  3. #13
    Gone
    Joel
    Picton
    pics of this totally awsome design?
  4. #14
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well ok maybe I didnt explain myself well enough, I mean have the fixed spring seat on the bottom and then the adjustable seat on the top so it winds down.
    I want to make my own up machining up everything but I need to find some kind of shockers that can handle the load put on them. Normal shocks arn't made for the force of a spring seat on them
  5. #15
    Pat
    oh ok
    what would be the advantages? just curious
    06/07/2011
  6. #16
    Endeavour Hills
    well I just thought it would mean the large diameter part would be at the bottom away from the tight area neat the shocker top, so no elongation would be needed or clearence issues there. But hey I havent had a good look, I would like to machine something up though, I think it would be an interesting project.
  7. #17
    Pat
    the tite spot is close to the middle. The cap that the damper bolts to isnt too deep and the elongation of the top hole jus allows the spring to sit further away lower down. Mine was elongated and it touchs very slightly on a small section about halfway down the spring, maybe a bit higher? was easy fixed with a hammer though
    Gillys coilover setup was one of the cleaner setups going around, and its a real pitty he cant keep the ball rolling on them cos i have only heard REAL good things about the dampers
    06/07/2011
  8. #18
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    sam if u ever decide to go through with testing / making kits id be very interested and in melb too, would love to learn more about designs and try them on my car see how it feels etc, i got some KYB short stroke super series shocks in my rear if u wana try it on them sometime
  9. #19
    Endeavour Hills
    yeah good to know. I have too many things to do right now and if we did something I think it would only be for use as there is too much involved to be viable business wise
    My initial idea on making a set was to just have a sleeve that literally slides over the top of the shocker body and is prevented from sliding down too far with a cap on the end. At the other end the shocker shaft goes through the body as per normal but I make a top hat fit over the shaft also. Or something along those lines. From what I have been told trying to get all the force of the springs to go through a bush at the end of the shockers is a no-go. WHat have others done to fix this issue?
  10. #20
    Dave
    Western Suburbs
    yer i well if you wana guinnea pig my shocks for it sometime just PM me anyway ay, but mine have the adjustable knob at the body if thats an issue, i can ask robo for a pic of his rear coilovers if you want? he may throw them this way if im lucky
  1. rear coilovers ae86
    By reecegze in forum Cars or Parts Wanted
    Last Post: 19th April 2010, 10:17 PM
  2. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  3. Rear coilovers for ae86
    By slydar in forum Car Parts For Sale
    Last Post: 7th September 2006, 04:32 PM
