Results 1 to 10 of 10
Thread: Can someone fix my rear brakes?
    Dave
    The Ghetto
    Default Can someone fix my rear brakes?
    hey guys just wondering if someone here would be kind enough to give me some tips. I have a jdm disc rear end but the brakes dont seem to lock up. Ive checked the pads and there seems to be still abit of meat left.
    I know its a rear disc end and they are shit at locking up but surely they're some way of improving the handbrakes (without just tighten the cable?). Sorry if this has been posted before.
    regards,
    dave
    Senior Member resol's Avatar
    steve
    vic
    better brake pads (softer compound), slotted rotors, better leverage.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    ey mate, try adjusting cables, if it doesnt help u prob got common problem like most
    (stretched handbrake cables) needa replace them, also check ur disks if they are glazed
    Senior Member Rhys.'s Avatar
    Rhys
    Mooloolaba
    I'll swap, mine are stuck on haha
    Dave
    The Ghetto
    thats guys i'll work on it this wkend. 'ae86' what do u mean if the disc are glazed?
    Veteran Skylar's Avatar
    Ken
    means they get coated and become smooth, like glass.
    You need to work them hard to get this layer off.
    Davey & Riki-lee
    South Australia
    Seaford SA
    Replace the cables i have a full set brand new genuine not sure if felix wants them still pm if you are keen
    Our introduction - Click here
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    the caliper 'floats' on two slides and these could need to be regreased. mine siezed up and the pads wore unevenly and worked poorly. i'll find a pic.
    steve
    vic
    stretched cables dont stop the brakes from working, just means you have to pull the HB further. if you cant adjust it tighter then yes replace them.
    glazed pads and disc's will be look shiny, use a course (400-600) grit wet dry paper on the disc with decent pressure, do tight spirals. and use a slightly finer grit (600-800) on the pads, same motion.
    a slotted/drilled rotor will help stop the pads from glazing up, help 'clean' the pad of water/dirt/dust etc and also add bite to the brakes. so that would be my 1st suggestion.
    softer compound pads will no doubt wear quicker, but thats where priorities come into it.
    -dan
    gunner:
    Dave
    Western Suburbs
    well stretched cables kinda depends how stretched, i had this problem so bad it could slow down my car but only under 50 k's and would only lock up 40% of the time, u can adjust it but only to a certain extent cause pads would be riding discs whole time wouldnt they ? anyway gets to a point where hbrake is too tight for my liking so i just replaced it all.
  1. 9'' rear drum brakes on a ae86
    By AIROCOBRA in forum Technical - Questions
    Last Post: 23rd October 2011, 06:12 PM
  2. T series rear brakes?
    By rs200 in forum Technical - Questions
    Last Post: 8th November 2010, 09:12 PM
  3. disc brakes at rear..
    By supaskua in forum Technical - Questions
    Last Post: 9th May 2010, 10:07 PM
  4. Rear Brakes caliper choice
    By lo_rolla in forum Technical - Questions
    Last Post: 16th February 2010, 03:21 PM
  5. Corona Rear Brakes Setup
    By Rallystanza in forum Cars or Parts Wanted
    Last Post: 9th July 2008, 06:29 PM
