better brake pads (softer compound), slotted rotors, better leverage.
-dan
hey guys just wondering if someone here would be kind enough to give me some tips. I have a jdm disc rear end but the brakes dont seem to lock up. Ive checked the pads and there seems to be still abit of meat left.
I know its a rear disc end and they are shit at locking up but surely they're some way of improving the handbrakes (without just tighten the cable?). Sorry if this has been posted before.
regards,
dave
-dan
gunner:
ALL DRIFT MODIFICATIONSYou're a fucking idiot, and I am ashamed that you are part of this community. Sure there isn't many tracks, but praticing on the street isn't the alternative.
ey mate, try adjusting cables, if it doesnt help u prob got common problem like most
(stretched handbrake cables) needa replace them, also check ur disks if they are glazed
I'll swap, mine are stuck on haha![]()
thats guys i'll work on it this wkend. 'ae86' what do u mean if the disc are glazed?
means they get coated and become smooth, like glass.
You need to work them hard to get this layer off.
Replace the cables i have a full set brand new genuine not sure if felix wants them still pm if you are keen![]()
the caliper 'floats' on two slides and these could need to be regreased. mine siezed up and the pads wore unevenly and worked poorly. i'll find a pic.
stretched cables dont stop the brakes from working, just means you have to pull the HB further. if you cant adjust it tighter then yes replace them.
glazed pads and disc's will be look shiny, use a course (400-600) grit wet dry paper on the disc with decent pressure, do tight spirals. and use a slightly finer grit (600-800) on the pads, same motion.
a slotted/drilled rotor will help stop the pads from glazing up, help 'clean' the pad of water/dirt/dust etc and also add bite to the brakes. so that would be my 1st suggestion.
softer compound pads will no doubt wear quicker, but thats where priorities come into it.
-dan
gunner:
well stretched cables kinda depends how stretched, i had this problem so bad it could slow down my car but only under 50 k's and would only lock up 40% of the time, u can adjust it but only to a certain extent cause pads would be riding discs whole time wouldnt they ? anyway gets to a point where hbrake is too tight for my liking so i just replaced it all.
