Results 1 to 3 of 3
Thread: 4age engine help
    Default 4age engine help
    hay there i have a small port 4age.
    im thinking of running some cams and a portjob in the head just a coupple of questions.
    1. will a bigport head fit on a smallport block ?
    2. whats the main differences between small port and big port engines
    Gone
    Joel
    Picton
    1. yes, all 4a blocks + a series heads are interchangable.
    2. its all in the name, small port has smallports and a big port has bigports
    Bigports had TVIS,
    some links
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    Over 200hp the bigport head will flow better under 200hp the smallport head will work better, from the info you have given sounds like you better just stick to smallport unless your planning to spend some big $$$.
  1. Zenki 4AGE engine loom for trade for Kouki engine loom
    By oz_eight6 in forum Car Parts For Sale
    Last Post: 13th August 2012, 05:20 PM
  2. Replies: 3
    Last Post: 12th January 2012, 03:35 PM
  3. Replies: 2
    Last Post: 7th October 2011, 11:28 PM
  4. 4age engine
    By otanica in forum Car Parts For Sale
    Last Post: 2nd April 2011, 12:45 PM
  5. 4age engine, 4age block, ecu, loom, gearbox
    By GZE KE70 in forum Car Parts For Sale
    Last Post: 5th March 2008, 10:12 AM
