Hi,
I have a set of Sard 1000cc Injectors here, with a top feed fuel rail. This rail requires aftermarket fuel pressure regulator.
The injectors have just been serviced and have not been used since. This cost $135. The injectors also flowed 1200cc/min.
Part number of the injectors is 195500-3650, I also have the injector plugs to suit if required.
Will post at buyers expense, but do prefer pickup if possible in case of freight damages.
Wanting $800 for injectors, $900 with rail (suit S13 SR20DET - can be spaced to suit S14/S15 SR20DET)
These injectors retail for around $315 each
Located in Wollongong, NSW
Contact via PM or call/SMS on 0424447419
Cheers.
