Results 1 to 10 of 12
Thread: how to remove steering wheel
    Khai
    Default how to remove steering wheel
    hey guys i might be retarded i duno how to take the s.wheel off, i have a standard sprinter wheel similar to this one:
    anyone know how to remove to put on boss kit and aftermarket wheel?
    Site Supporter Javal's Avatar
    Josho
    Standard ADM or JDM wheel?
    If ADM:
    get small screwdriver, pry the center "S" or "C" badge out from the steering wheel. Put the screwdriver underneath the badge in the middle and pry. Should come out easy. Then there's one 17 or 19mm nut (i forget) to undo. Undo it most of the way but don't remove it yet. Then wiggle and pull the steering wheel (can take some force) toward you to til it comes loose. THEN remove the nut and take the wheel off.
    JDM: same as above, but instead of prying out the badge, you just pull the 'toyota' bit off towards you.
    Fitting the aftermarket wheel should be very straightforward.
    Khai
    man the wheel is not budging
    Josho
    It takes a bit of force. Hitting doesn't work. Just pull and wiggle.
    todd
    fucking smack that shit harder.
    dare you to take the nut off though, its scary/funny/painful when it comes flying towards the bridge of your nose.
    todd
    tapping around in a circle does.
    Davey & Riki-lee
    South Australia
    Seaford SA
    put the knees on the bottom and pull using your knees and bang the top parts of the wheel towards you and boom!shes off
    Our introduction - Click here
    Veteran Robo86's Avatar
    Rob
    crack the bolt, unscrew a few turns, belt the cunt
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Khai
    finding it difficult to attach the boss kit and quick release without putting them on crookered, will try tomorro. any tips?
    Josho
    Yeah. Remove the steering wheel at straight ahead, then dummy fit at straight ahead. Bolt it down. Test.
    Rinse, repeat.
  1. Replies: 3
    Last Post: 29th November 2011, 08:20 PM
  2. Replies: 5
    Last Post: 18th April 2011, 03:56 PM
  3. Remove AW11 Steering wheel
    By aexx in forum Technical - Questions
    Last Post: 27th April 2010, 05:15 PM
  4. How to remove power steering arms from car?
    By patience in forum Technical - Questions
    Last Post: 11th July 2008, 11:59 AM
  5. how the hell do ya remove a sprinter's steering wheel?
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 25th November 2006, 01:38 PM
