I did a similar thing but I also soaked them in De-solve-it to breakdown the adhesive first.
Didn't do any harm to my paint either.
Most ppl fail doing this as they just yank em off and they bend.
Once this happens. say bye bye to your side mouldings.
Personally, I like them for road cars. Nothing worse then a trolley dent due to some twat in a carpark.
Tools
1 small hammer or rubber mallet
1 plastic scrapper/spatula (I used an old one from gyprocking some plater)
The reason for the plastic spatula is that over metal. You will be less likely to scrape the metal off your door.
Step 1. Insert spatula into side of door moulding
Step 2. Hammer Spatula
Step 3. Ease the rubber side moulding off slowly (not more then 2 inches/ 5cm )
Step 4. Repeat steps 1-3, slowly moving the spatula up as you get through it.
Notes: Be warey that previously resprayed cars may get some paint lift.
Do this at your own risk.
If anyone knows of a better way, please post it.
Silver 86 Trueno Hatch.
AE86 4age gear for sale - http://www.ae86drivingclub.com.au/fo...eats-Ae86-gear
Side intrusion bars for your import - http://www.ae86drivingclub.com.au/fo...our-JDM-import
that de-solve-it stuff and a piano wire? if you pull sortof away from the car you shouldn't hit the paint.
I personally wouldn't use a piano wire as it might scratch your paint.
If you do happen to bend them....they can be heated and straitend at any decent panel beaters!
Will post pics after I have it done on the markII....getting 2 doors repaired,the strips are badly creased!
43ger
Performance
SINCE 2008
i did the same thing as the first post but i used a hair dryer as well just to soften the adhesive and the adhesive came off the paint with the moulding i was very happy with my work
shit ain't hard. if ape like panel beaters can do it, so can any one.
i made a balls of this,lack of patience=retard!i used a heat gun and a screwdriver,wasnt workin well so rippe them off,left loadsa scrapes, but hopein for a resprey soon anyway, no wonder i get my mate ta do all car related stuff for me!!
Ive used mig wire on a hot day very effectively before
used plastic spatula and hammer, worked well but now for the degreaser to get the left over rubber n glue off, any advice on that?if not thanks anyway this was very helpful
joe.
4-ac stock sprinter.
