Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: Another ghetto Panda
    Member ONCE-NA's Avatar
    Rod
    Ballarat
    Default Another ghetto Panda
    Copied from toymods, I picked this up early this year and havent really done much to it untill now.
    Rust in rear arches have been repaired allready, (Looks like its been done properly too!) The body looks very straight, I gave it a good wash and couldn't find a dent in it!
    Only rust I have found is in the passenger side door at the bottom on the inner, the skin seems to be okay. It came with the front lip that is on it and side skirts (which arnt fitted).
    Oh yeah, dash has no cracks, just the thin hard plastic bit above instrument cluster has a slight crack. and the rest of the interior is great, abeit dirty.
    Its only got a 4AC but I have plans to fit something better. It has briefly crossed my mind to part out the 22 and use some of the bits for the 86...
    Rod
    Ballarat
    Ebay J-Blood copy wing turned up, it fits like, well, like its for a different car! Lol
    Don't think I'll end up using it, I would take ALOT of work to get ir right...
    Anyways, got 4 days off so I'll start getting it ready for paint!
    Rod
    Ballarat
    Stripped out, getting ready for paint
    Found some rust in the hatch, GRRR!
    Folded up a new bit of steel and welded it in, took it slow but still managed to warp it a bit...
    Rod
    Ballarat
    Had a bit of progress...
    Also I've got a bit of stuff to go on once its all put back together.
    8kg/mm & 6kg/mm springs F/R
    New front and rear short! shocks
    AJPS Adjustable panhard rod
    Whiteline front strut brace
    New clutch master and slave cylinders
    New rack ends
    New balljoints
    New Rack bushes
    New rack boots
    New suspension bushes (Everything)
    New pedal pads
    Got a completly rust free hatch!
    Iffy aftermarket steering wheel
    Long boss
    Boost, water and oil temp guages
    JDM levin grill
    16 x 8 Rota grids, or 15 x 8 Rota RB's (Havent decided which will go on this and which will go on the TA22)
    Under car surge tank
    Smallport 4AGE (came with a stainless turbo manifold and T25)
    Standard ECU
    So i'm looking for a complete loom for the motor and any bits needed to make it go, i'll be running it NA for a while. So stuff like loom, map sensor, ignitors, coils etc and extractors.
    edit: Oh yeah and a set of white body bump strips!
    Dan
    Vic
    Western Subs
    Nice mate, i love reading build ups - i do have a complete loom and ecu but its a bigport one
    anyways gl with the build!
    . h i t o r i k o .
    Veteran corknose's Avatar
    Callum
    looks good and should be a good setup once its all done, are you gunna put the other white line on the body for the panda or just leave it?
    User fantapants's Avatar
    Pat
    they are the white bumpy thing arnt they?
    06/07/2011
    Rod
    Ballarat
    Yeah the white stripe is the bumpstrip only. I have an incomplete (and rough) black set that I could paint, or I could possibly use a white vinyl strip meantime till I can source the proper thing.
    Rod
    Ballarat
    Got a bit more done: Doors, bonnet, front bumper and hatch on. Wheels on, rear quarter glass in, fuel door on. I've been painting cleaning etc. everything before it goes on so its taking a long time to get it back together.
    Rear bumper and side skirts not painted yet, was hoping to get a better bumper or a lip or pods for it first.
    I got a bit carried away with the rear arches, I need more offset now!
    Rod
    Ballarat
    There's been a little progress...
    I may get flamed for using smoked tailights but they were half the price of second hand red or whitelines so they will do for now
  1. Ghetto bus
    By wagonlife in forum Other Toyotas
    Last Post: 12th August 2012, 11:44 AM
  2. Ghetto fixes
    By snake in forum Offtopic Discussions
    Last Post: 5th May 2008, 02:34 PM
  3. FS ghetto KE70
    By ke_slide in forum Cars for Sale (Toyota Only)
    Last Post: 21st April 2008, 07:09 PM
  4. Ghetto gaurd rolling.
    By 20sil in forum Technical - Questions
    Last Post: 31st March 2007, 12:54 AM
  5. ....::My Ghetto Spec KE70::....
    By 20sil in forum KE70 / AE71 Owners Forums
    Last Post: 25th February 2007, 08:29 AM
