Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 11 to 20 of 55
Thread: Swaybars
  1. #11
    Veteran Konakid's Avatar
    Henry
    Eastern
    swaybars are one of the best mods you can do to your car, if you dont have one id get one in the rear asap.
    make the car so much more fun to drive and much more predictable.
  2. #12
    Jun 2009
    Grant
    California
    San Jose
    USA
    Do you think the rear Celica sway bar will bolt up to an ae86? Might be a cheap alternative to an aftermarket rear bar.
  3. #13
    Senior Member greeneyes's Avatar
    Vlad
    Sacred Valley
    Cusco
    Peru
    It went straight into the KE70, so I expect it will fit the AE86.
    I used the Celica bushes as its 1/3 thicker again.
    here's the article-
  4. #14
    Senior Member awang's Avatar
    Zul
    Brunei
    Stone City
    Brunei
    so what if the car is strictly for street daily driven car
    is it worth it investing on this aftermarket sway bar?
    sorry not tend to hijack the thread, just wanted to gain knowlege since you guys actually using one and experienced this first hands
  5. #15
    Senior Member GOODY's Avatar
    Logan
    Thanks for all the help guys, I actually seen that writeup about the RA60 swaybars but I couldn't find one when I was at the wreckers last..
    Adjustable sound like the way to go even if I only get that on the front and pick up a ra60 bar if I can find one. Or if I can get a good deal somewhere then they will both be adjustable
    Can anyone confirm anything about the front whiteline adjustables fouling on the struts??
    Also just for reference my setup is listed below.
    Front: HSD sleeve kit, 86 struts, 7kg springs, trd yellows, xt130 lcas, 86 pwr steering arms, whiteline strut brace
    Rear: Hilux diff, adjustable panhard, excel g shocks (VL wagon?), cut falcon springs, NO sway bar, traction brackets, adjustable lower arms
  6. #16
    Logan
    Double post
  7. #17
    Senior Member resol's Avatar
    steve
    vic
    as far as the whiteline bars hitting the struts havnt had any issues, its more a relationship of the LCA to the strut then anythign else that would foul.
    where abouts are you located?
    if its on the cheap, then a thicker rear bar will increase the tendancy to oversteer. however i like a balanced car. so i have both, the rear is as tight as it will go and the front is one step back. this is so that at the limit (depending on tyres etc) the car will oversteer, IMO a 'safer' way to lose grip.
    i would ditch the ford springs, they are way too firm for a rolla, even with a hilux diff under it. 7kg front and 5kg rear would be a better match. this is all my opinion though
    pm sent regarding whiteline bars.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  8. #18
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    I had problems with my front calipers hitting the Whiteline Adjustable Front Swaybar, but that was with RX7 4 Piston Calipers. You don't mention brakes so I am assuming STD or JDM.
    I might have had some rubbing between strut and swaybar when the car was jacked up, and the wheels drooped to full extension, but when on the ground would correct and not be an issue.
    I have since changed from the Whiteline Adjustable front to a CMR Hollow non-adjustable item. Mainly due to the caliper issue, but I also don't like the whiteline adjustable stuff much, it is not very well designed.
  9. #19
    Veteran Skylar's Avatar
    Ken
    Solid anti-roll bars are dead weight. and whiteline's old bushed endlinks on their adjustable ARB's suck.
  10. #20
    Timmy D
    North
    i had a "upgraded" sway bar on the rear (not sure how big) and the car was stepping out at the top of my gears, which threw the hills just scared me and stopped me from driving quicker. i removed the sway bar and now im much quicker around corners. there is quite a fare bit of body role now though.
    if you want it to slide a bigger sway bar will help this, from my experiance
    JJ
  1. TRD Swaybars
    By Otaku in forum Cars or Parts Wanted
    Last Post: 25th November 2012, 05:42 PM
  2. Whiteline swaybars
    Last Post: 1st November 2012, 11:03 PM
  3. Whiteline Swaybars
    By shawn_26 in forum Technical - Questions
    Last Post: 7th April 2009, 05:29 PM
  4. Swaybars
    By keto in forum Cars or Parts Wanted
    Last Post: 2nd April 2008, 01:22 AM
  5. Swaybars, clutch
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 16th February 2008, 01:58 PM
