Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 40 of 55
Thread: Swaybars
  1. #31
    Glenn ke_70's Avatar
    Clay
    Barossa!
    so will a rear bar even things up abit?
  2. #32
    stefan
    vic
    eastern suburbs
    ra60 is the same as a jdm ae86
    so its not as bigger upgrade as you might think. its only just noticably better than a standard sway bar
  3. #33
    Senior Member stouty's Avatar
    Leigh
    Forster
    I have a T-18 and use it for hillclimbs and Supersprints. I had 18mm rear and found i didnt have any movment im my rear end and would pick up the inside wheel on tight corners so i removed it and its so much better.
    Now run no rear swaybar, 24mm whiteline front non adjustable but i am going to swap back to standard 21mm as i have a little understeer. I think it will be awsome i run 7kg front 5kg rear.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
  4. #34
    Leigh
    Forster
    Grip TE72
  5. #35
    Senior Member greeneyes's Avatar
    Vlad
    Sacred Valley
    Cusco
    Peru
    Yep, the next A60 Celica in line at Great Western wreckers in Orange still has its sway bars. If anyone wants it I can get the rear and mail it somewhere, or if you're going to the Bathurst 1000 this weekend we are just down the road...
  6. #36
    Jun 2009
    Grant
    California
    San Jose
    USA
    I just found out TRD rear sway bar is the same as USDM rear sway bar =(
  7. #37
    Senior Member resol's Avatar
    steve
    vic
    it will certainly help.
    stouty: if you were lifting the rear wheel i would be suggesting that you dont have enough negative travel in the rear. sway bars/track increase would be better mods for hill climb then stiff springs. what shocks are you running, and how low is it?
    and of course by removing the rear sway abr the front has become the stiffest end and now the car understeers. i'd chuck the rear bar back in and rethink the shocks perhaps.
    **captive springs are good, but springs that are too captive are known as preloaded. which actually reduces the negative travel and increase that 'bounce' the car gets under braking or on bumpy surfaces. which means they handle like shit. preload is used to adjust the negative travel (sag) of a car and thats all.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
  8. #38
    Veteran Skylar's Avatar
    Ken
    put the stock rear anti-roll bar back in. maybe. I'd just leave it off.
  9. #39
    Timmy D
    North
    dont forget when putting your sway bars in that with the car on the ground there is no "bind" as in the sway bar is not set to high or low it should be set at a height that it is free to just sit there.
    i read it.... in a book
    JJ
  10. #40
    Leigh
    Forster
    I have TRD 8 way adjustable green shocks in. Guard sits about 10mm above tyre. So its low but not over the top. I actualy like the way the rear of the car feels without the rear swaybar in.
    Can you suggest some shocks that will suit better as im looking at changing them and the rear spring rate.
    Grip TE72
  1. TRD Swaybars
    By Otaku in forum Cars or Parts Wanted
    Last Post: 25th November 2012, 05:42 PM
  2. Whiteline swaybars
    Last Post: 1st November 2012, 11:03 PM
  3. Whiteline Swaybars
    By shawn_26 in forum Technical - Questions
    Last Post: 7th April 2009, 05:29 PM
  4. Swaybars
    By keto in forum Cars or Parts Wanted
    Last Post: 2nd April 2008, 01:22 AM
  5. Swaybars, clutch
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 16th February 2008, 01:58 PM
