Results 1 to 7 of 7
Thread: Diff help needed 1.5way
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default Diff help needed 1.5way
    hey all just got a 1.5 way diff from Irish Paul and I got it home where I when to test it and correct me if I'm wrong but isn't there supposed to be give in the diff like if I hold 1 axle won't the other axle turn but be a little tight this diff has no give is this just a tight diff or a locked center any help on shedding some light on this would be great
    mat
    the dyno pull to 300rwkw
    Veteran Skylar's Avatar
    Ken
    MAN UP and put some force behind it. Get broome handles or something across the studs/wheel for leverage.
    Mathew
    Sutho Shire
    so its gonna be tight then ay well them I'll put my back into it them
    Veteran Rice86's Avatar
    Richard
    Liverpool
    just install it and test it out ??
    dose
    Mathew
    Sutho Shire
    true true see how she goes in the car but i am for sure changing the oil in it so would any1 on here have good experiences with a good oil for it? its TRD 1.5way suggestions?
    there shouldn't be any give from hand force...
    i have a nismo 1.5 in my r33 and when one wheel is off the ground you can not turn it.
    diff holds 300rwkw all day every day
    Richard
    Liverpool
    just get them LSD castrol diff oils...=]
    dose
  1. NEEDED: T SERIES DIFF
    By Gunner in forum Cars or Parts Wanted
    Last Post: 9th January 2013, 02:23 AM
  2. R31 DIFF NEEDED!!!
    By Catch My Drift in forum Cars or Parts Wanted
    Last Post: 10th August 2012, 10:23 PM
  3. whats better 1.5way & 2way??
    By Y-B-NRVS in forum Technical - Questions
    Last Post: 2nd June 2010, 11:41 PM
  4. STRONG DIFF NEEDED
    By ardon_t in forum Cars or Parts Wanted
    Last Post: 24th January 2008, 12:30 PM
  5. Diff centre help needed
    By stinger_007 in forum Technical - Questions
    Last Post: 21st June 2006, 04:19 PM
