Very clean looking e7, Ross. Looking forward to seeing it's progress!
Soo . . thought it was about time I stop trawling the forums and post up a ride thread.
Dicey is a AE71 5 Speed Manual. She was bought from West Lakes, where she resided as a drift pig.
- Backyard Weldy
- Makita Cut Springs
- Grip Tap Handbrake
- Matt Black Stockies
- Clutch plate nearly shatted
- License plate shifted for better cooling
However the body was straight, and the rust was fixable. I also wanted one which I could build up myself, so being a drift pig didn't worry me
Now she sports some better running gear and a bit of work has been put into getting her running better, thanks to S2, AJPS and Fisher Racing
Setup as of current:
Front: - Selby 24mm adjustable swaybar
- AJPS 6KG springs
- AE86 Struts
- AJPS Ajustable Tie Rod Ends
- AE86 Powersteering Arms
- AJPS 40MM RCA's
- Koni Short Stroke
- XT130 LCA's re-bushed and ball jointed
- Castor Bushes, with adjustment maxed out
- Camber / Castor tops
- AJPS Kelway Strutbrace
Rear: - No swaybar
- T18 Diff, with custom tailshaft
- KYB shockies
- AJPS Adjustable Panhad Rod
Running 14 x 6 Delta Mesh with Yoko's currently
Cheers Fusion
Cheers Sven, its not bad for paint actually has an alright shine, however it can be a little patchy. Dreny's rig looks alot tidier though, gives me a bit of inspiration I must say haha
Spoke to the engine builder today, looking at just freshening up the 4AC for now with electronic ignition, a 32 / 36 Weber, and maybe a cam of some sort. Hopefully get it done in the next month
Cheers Fusion
looks good man. i'll keep an eye on this one YEAH!
Cheers Kkustom . . . Diffs making bad noises, so it may be time to sort that out to. Not to sure what to do yet though, might just chuck a welded chunk in it for the time being.
did u buy this from a dude named tom?
Can't remember the name, may of been. From the West Lakes area? Was doing up a skyline or something?
yeh from westlakes. a 32?
Might of been. Not 100%. Know him?
