Results 1 to 8 of 8
Thread: 4k Overheating
    Junior Member flynnske's Avatar
    Default 4k Overheating
    My 4k keeps over heating and it doesnt have a thermostat and its not blocked or anything so what could it be? could the water pump or something be fucked?
    any help would be great
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    Is there brown muddy looking shizz inside your radiator / underneath the radiator cap? If so, take it out and clean it out with a hose. If that isn't the case / doesn't do anything, take your water pump off and have a look inside, if it looks foobarred then replace it. If that doesn't do anything. take it to a radiator place and get them to check it out. From what you've said it sounds like a water pump failure to me.
    Senior Member resol's Avatar
    steve
    vic
    check for BHG. what colour is the coolant?
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Senior Member greeneyes's Avatar
    Vlad
    Sacred Valley
    Cusco
    Peru
    Does it lose water?? Not something silly like fanbelt too loose to drive it.. although that would give alternator squeal at night...
    No drips or puddles on the ground?
    If you had a thermostat in it you could do a quick check for a head gasket leak, but w/o it I think you'll need to try the stuff you put in the rad and it changes colour, or a leakdown pressure test.
    Kieran
    does it use coolant?
    you may have a small leak.
    Dan
    Vic
    Western Subs
    i'll put money on head gasket - or if its an auto, the radiator, or check your clutch fan if that free spins it might the reason too
    thats my experance with 4ks
    . h i t o r i k o .
    Site Supporter Javal's Avatar
    Josho
    You know what, forget what everyone else in this thread has said.
    FIRST THING TO DO - TAKE YOUR RADIATOR CAP OFF AND HAVE A LOOK AT YOUR COOLANT.
    Is it really off colour? Is the level low? Is there even any in there?
    You'd be surprised how often retards say 'oh, my car overheated, i did my waterpump and headgasket and it's still overheating'.
    NEXT:
    Check the cooling systems for leaks. 90% of the time there's staining or fresh coolant. If there is no coolant in your cooling system, put some tap water in for diagnosis purposes.
    Get a torch, check for staining or leaks. Check your radiator (around the cap too), hoses, welsh plugs, heater hoses, thermostat housing and water pump.
    Get a hold of a pressure tester if you can.
    Still nothing?
    Start her up with the radiator cap off but full of cooling system full. Constantly bubbling? Do a compression test to check for BHG. It would have been blowing white smoke and running grumpily beforehand though.
    Davey & Riki-lee
    South Australia
    Seaford SA
    i replaced so much shit on mine to find my dash was coroided and gave a shit reading lol but there is a few things there
    Our introduction - Click here
  1. 4age overheating
    By Sprinter Freak in forum Technical - Questions
    Last Post: 1st October 2012, 09:58 PM
  2. Overheating problems
    By Stej in forum Technical - Questions
    Last Post: 10th November 2010, 07:13 AM
  3. Brakes overheating
    By flamingheads in forum Technical - Questions
    Last Post: 10th December 2009, 08:23 PM
  4. Engine Overheating
    By fozz in forum Technical - Questions
    Last Post: 17th September 2007, 02:03 PM
  5. Overheating 20v
    By _matt in forum Technical - Questions
    Last Post: 11th November 2006, 10:08 AM
