Results 1 to 3 of 3
Thread: coil pack troubles
    Davey & Riki-lee
    South Australia
    Seaford SA
    Default coil pack troubles
    Car - ke70
    motor - 4agte
    problem - Well turns out you cant use the toyota ignitor with an after market ECU (Adaptronic), Adaptronic have an ignitor but im not sure how many i need? as i am using the toyota coil packs, so they are 1 coil for 2 leads and there for 2 coils for 4 cylinders.
    What i need to know is, can i use 2 adaptronic igniters or do i need 4? lol
    Also wondering does anyone know anything about the bosh coil packs? like where to get them? how much? etc?
    Our introduction - Click here
    Site Supporter Javal's Avatar
    Josho
    Use 2, run wasted spark.
    Why the hell can't you use the factory ignitor. Doesn't it only need a trigger signal from the ECU?
    Veteran Skylar's Avatar
    Ken
    There's IGt, IGf like normal and an IGd. IGt tell it when to spark. IGd tell it which one to spark.
    on 7M-GTE and such, there's IGdA and IGdB to determine which one to spark.
  1. How to Wire coil on plugs? 20v ST w/ Aftermarket ECU w/ 4 coil pack
    By Fine Taste in forum Technical - Questions
    Last Post: 5th August 2014, 07:50 PM
  2. 2nz coil pack
    By evil86 in forum Car Parts For Sale
    Last Post: 8th January 2012, 10:10 PM
  3. 4AGE Coil Pack power?
    By bally in forum Technical - Questions
    Last Post: 28th February 2011, 10:00 PM
  4. coil pack and ignitior
    By ca18ae71 in forum Cars or Parts Wanted
    Last Post: 15th June 2010, 11:07 AM
  5. 4agze coil pack
    By deafkid in forum Technical - Questions
    Last Post: 30th May 2007, 08:17 PM
