Results 1 to 6 of 6
Thread: 5v square tach pulse?????
    Senior Member slideways's Avatar
    Tristan
    Default 5v square tach pulse?????
    Just got my new replacement igniter from EMS, and the new design doesn't have a tach output from the igniter.
    So how can i get a 5v square wave tach pulse from the igniter/4 bosch coils?
    Anthony
    which ecu?
    Tristan
    stinger 4424 v.3 w/ 2 outputs both in use
    Veteran Skylar's Avatar
    Ken
    link the 4 ignition outputs to one wire through diodes?
    Tristan
    This is what I thought, but wanted to make sure that it works. Also which diodes do I use?
    Ken
    1N4004 should be fine.
  1. Weak injector pulse
    By Matt in forum Technical - Questions
    Last Post: 18th December 2011, 11:54 PM
  2. No injector pulse on 4agze
    By Sprintn in forum Technical - Questions
    Last Post: 19th September 2011, 06:09 PM
  3. no injector pulse 4age
    By cozmic in forum Technical - Questions
    Last Post: 7th February 2010, 10:56 AM
  4. Should pulse be used for stick welding?
    By Vezza in forum Tool Talk
    Last Post: 6th September 2009, 07:36 PM
  5. injector pulse
    By johnO2 in forum Technical - Questions
    Last Post: 30th July 2008, 12:28 AM
