Results 1 to 9 of 9
Thread: 2 questions please help
    Scammer, DO NOT BUY FROM ME!
    Default 2 questions please help
    i got a question for you. i think ive done another headd gasket. when i open oil cap ther is no milky colour and it smells fine but when i undo radiator its got a bit of sludge in it and it kinda smells like exhaust. do u rekon thers a cracksumwhere in ther? its a 4k btw
    also i got a solid rear end in my ke70 wagon. on the left hand side i got pos cammber and on right i got like 1.5 degrees neg camber what do ya rkeon it could be?
    all help is appriciated.
    yea thats what i was thinking. is ther a way of temp fixing it so itll last another month or 2 till i can go 3t?
    Dave
    unfortunately not.
    luckily you can change a 4k head gasket in like 3 hrs or so. though you should get the head machined while your at it.
    - Blaise Pascal
    how much does that cost? if i nana the car how long u rekon itd last?
    Senior Member resol's Avatar
    steve
    vic
    just drive it "blown" 4k are tuff!
    does the engine over heat easily?
    does it use water? i.e after a day or 2 there is noticably less water in the rad?
    are there any coolant leaks?
    have you comp tested the motor?
    these are some of the things you need to do to check if the head has poped.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Veteran biggo's Avatar
    Nick
    Noosa
    You could also get a sniffer test done at any reputable workshop.
    Do you have cut springs in the back?
    yea car was on flat ground at the time. umm yea no leaks or anything. deffs has less power. it dropped alot of fluid for a day then got better. also i bought sum chemiweld to temp fix it. does anyone have a proper way of doing it as ive herd sum bad fuckup stories of where it dries in top of radiotor and fucks it up.
    West
    Just shake the bottle, pour iot in and run it for 20 minutes. It will usually do something, maybe not much but something.
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    Don't use chemiweld! Chemiweld is shit!
    Use a bottle that is clear and is called, metallic sealup. It's got clear fluid in it and copper particles in the bottom.
  1. few questions
    By fergie in forum Technical - Questions
    Last Post: 8th July 2010, 10:51 PM
  2. Few questions.
    By Dish in forum Technical - Questions
    Last Post: 25th April 2008, 09:21 PM
  3. Few Questions
    By damo46 in forum Technical - Questions
    Last Post: 25th April 2008, 03:38 PM
  4. A few questions
    By Gullie in forum Technical - Questions
    Last Post: 15th April 2008, 02:13 AM
