get springs from lawson from ajps cheaper better and he'll help you get the right rates
id also go 15s if you really want a change
Engine: 4A-GE 20valve ( Needs After Market ECU)
Exhaust: TRD Extractors With 2.25inch All Through With 3inch Tip
Suspension: White Line Sway Bars, Strut Brace With Stock Shocks and Cut Springs Not Very Nice ( Want Cheap KE70 Kings Front And Rear And Also Camber Top For Front For Now)
Wheels: anz Ghosts 18x7.5 ( Want Tanky Drift Wheels With Good Offset Hopefully White Rota Grids )
Modifications: 20valve, Full Tan Interior, Paint, Wheels, Tail Shaft ect ect
Stereo Audio / Visual: Pioneer DVD With MTX Splits
Estimated Power: Not Sure
Just Posting This To See What Ideas People Give Me On How To Do it To Make It A Show Drifter
Wanting To Do To The Car
*Fully Adjustable Coil Overs
*16x8 White Rota Grids
*Microtech ECU
*Remove as much unwanted plastics as possible
*Convert Cluster To Full AutoMeter Set Up
*Door Trims To Sheet Metal
*Quad Light Conversion
*Front And Rear Chrome Bar And Front Bottom Lip Like Grant Scotts AE71/KE70
Just Throw Me Some Ideas
That will make the car look about, hmmm, 10000000times better than it does now.
yea all good man just really stuck with the coil overs and all the sus. not sure what to get like i can get ae86 coilovers but not sure what mods are needed
do exactly as konakid said and this will be dope.
just a recap on the aesthetics.
Black Mirrors
Black Bars
Black Wipers
Black grill minus the toyota badge
and some 14x7 +/- 0 offset wheels would be perfect.
and most definitely change the number plate to random letters and numbers.
all people need these days is your number plate make a call and you get fucked over. cmerln is way too easy to remember.
also buy sundee86's coil overs.
vid
People say less TALK More ACTION , I say More TORQUE Less TRACTION
Ok, so out of 9 pages of Bull shit, there was 8 ok posts to leave up.
Lets try and keep this Members ride thread helpful to '4A-G3' but at the same time let him do what he wants.
You all need to realise its not your car, he can do what he likes with his car. If he asks for guidance, give it, otherwise, STFU and keep negative opinions to yourself.
Shattered....none of mine made the cut!
Should be a good thing when your done with it man!
look forward to seeing it de pimped!
Good luck with it all!
Josh
43ger
Performance
SINCE 2008
