Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: BT 20v Head, t50, Carrillo's , 7 rib, crank
    Gunner
    Default BT 20v Head, t50, Carrillo's , 7 rib, crank
    1. AE111 Black Top head, complete, it has been ported to within an inch of its life, all testing has been carried out on a flow bench.
    I will supply rwd cooling gear, and davies craig electric water pump and radiator hoses, one is aluminium.
    Pics later
    sold
    2. JDM T50, with shifter, I bought this off Beau earlier in the year for mock up, he was unsure of condition, I never bother looking at it, It appears to be only bearings though.
    I payed $100, you pay $100. pick up only. SOLD
    3. 4AGE carrillo rods, these are the shit when it comes to rods. One has had a spun beaing, which appears to have been very minor. Will require a visit to the machine shop. This require a piston with a 19mm wrist/gudgeon pin.
    Pics are in my build thread.
    sold
    4. Ae111 7 Rib block, with squirters, will incude oil pump and rear plate. STD bore, shaved deck (????measurements) Good, ready to use.
    sold
    5. AE111 crank, STD journals, ready to use. Came from a running low k bt.
    SOLD
    6. AE111 Altenator in good cond, with bracket.
    $100
    7. RWD 4age starter, $50
    8. Custom engine mounts suit 4age to 86, pics in build thread, $80
    9. Complete silver top head, $150
    10. AE111 sump, extra bung for temp sensor. $50
    11. 4age dry sump pan. sold
    12. Large alloy radiator. $200
    13. CAMS spec Catch can and overflow, bolts in front left corner. sold
    14. Pair performance meshies 15x7, +10, one has a gouge still holds air, have tyres with 20% tread, good skidders $100 (pics n thread, the ones on the rear, also in cressy thread)
    15. ADM brown and yellow front seats, goond cond, no tears, $40 pair.
    16. RWD water kit, with ewp, $300
    All parts in Liverpool.
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    I'm keen on that T-fiddy.
    What afternoon can I pick up this week?
    Site Supporter
    chris
    Queensland
    Nundah
    I'll take the crank.
    will you post to Brisbane?
    PM me with some bank account details.
    Gunner
    pm'd.
    Gunner
    Will swap the head for wheelage in the 15x8 +10 to -25 ssr mesh range, or mk111's and I'll be your friend
    Gunner
    crank sold
    Gunner
    updated
    Gunner
    updated
    Will sell block, rods, and head for $1250 if sold this week.
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    i'm keen on the t-50 also
    pm if sale falls thru.
    bursting ovaries since 92'
    Gunner
    t 50 sold
    If some one likes they can come take all of that plus what ever else I find, for $1600.
  1. BT 20v head bolt replacement
    By _sawyer_ in forum Technical - Questions
    Last Post: 17th May 2011, 07:38 PM
  2. WTB: 20v bt/st engine and t50 gearbox
    By ballos in forum Cars or Parts Wanted
    Last Post: 16th May 2011, 11:41 PM
  3. Is there a difference between bt and st 20v head???
    By slider4life in forum Technical - Questions
    Last Post: 12th July 2010, 07:50 AM
  4. wtb: BT 20v crank
    By 84ae86coupe in forum Cars or Parts Wanted
    Last Post: 30th July 2008, 08:07 AM
