Results 1 to 10 of 12
Thread: maxing my castor?
    Senior Member .ady's Avatar
    Andy
    Footscray
    Default maxing my castor?
    Car - spoontar
    motor - na
    use - na
    problem - wheels will rub against front bar?
    occurs/started when - when i plan to max my castor?
    personal situation -
    ohk so i plan to max my castor but i've been reading/ i know that i need to cut my front bar slightly....i just want an idea how much to cut off, tools you guys used during the process i.e jigsaw? please note ive got stock castor rods and obviously plan to max them.
    with the pic above i plan to cut along there but i want to keep as much of my front bar as i can jst becuz i want to? and also do i need to go all the way down or sud i stop somewhere?
    i hope hao doesnt mind me using this but
    is that cut too much? or jst enough?
    EDIT: stock castor rods will be maxed out...current hieght i think is 210mm? might go 200mm pending how my new wheels sit
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    I don't mind
    Do what Dave said man. My current bumper is spaced forwards with washers. Don't wreck your bumper, that one^ was cut when i got it so I had no choice.
    Andy
    Footscray
    yea i prob will do that then... easier then hacking my front bar... does it look weird tho? got piccys
    Senior Member resol's Avatar
    steve
    vic
    do you even know why your maxing your castor, or are you just doing it because you read it on the intawebz?
    run as much as you can without it scrubing on the bar, if after driving it you want more then by all means wind it up more. spacing the bar forwards seems to be the thing to do.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Veteran Rice86's Avatar
    Richard
    Liverpool
    yeah...i did this...was told jsut feels better...i ended winding mine a bit further back...max castor didnt fit my driving style..80-90% was perfect
    as to scrubbing on the bar...moving it forward is best and if still need to be, then chainsaw that shit and cable tie spec is street credit
    dose
    steve
    vic
    yeh true. not to mention max castor + max camber = fail understeer.
    theres no option but to chop on *E7*, and i think the guards might be closer too...
    -dan
    gunner:
    Andy
    Footscray
    you got me dan! i have to come clean and be honest now...yea i dnt know wot it does...i jst do it cuz i saw it on the intawebzzzzzzzz
    also i dnt know wot adj sway bars do nor do i know wot ibs are i jst think they look and sound kool....i saw it on the intawebz and alot of people have it on here so i thought to myself fuck thats JDM AS so i did it tooo
    ohh i even bought a ae86 truneo bcuz i saw it on initial d and everyone knows THAT IS FUCKING JDM AS FUCK! so fucking + rep for me
    i think i've said enough....i dnt want to embarass or myself look like a dick anymore
    thanks for the help and feedback...keep us posted on ur mods so i can be jdm too
    steve
    vic
    +rep
    -dan
    gunner:
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Talking
    not trying to Hijack
    with the caster+camber= under steer fail, are you meaning it reduces under steer or increases it
    Veteran hachi_dk's Avatar
    Filip
    Jozzaville
    hes saying too much of both causes understeer.
    theres a balance to achieve better handling and maxxing everything is not the way
  1. castor rod help
    By ke.slider in forum Technical - Questions
    Last Post: 26th September 2010, 11:06 PM
  2. castor rods
    By jay70 in forum Technical - Questions
    Last Post: 31st August 2009, 09:40 PM
  3. castor
    Last Post: 15th May 2009, 12:29 AM
  4. Castor rods
    By Robo86 in forum Cars or Parts Wanted
    Last Post: 13th June 2008, 10:24 AM
  5. Castor
    By biggo in forum Technical - Questions
    Last Post: 2nd March 2006, 11:04 AM
