anyone ? seen people post this up before and cant find the threads! help me out!
Hey all
Im after a map for my adaptronic, motor is a 4agze has cams, turbo, not sure what other info to put?
any help would be great!
cheers,
davey
well i am going to google it to find out what your meaning , then i will try and help
OOOECU
use a 20v base map off aptronic's site and make a boosted base map if you can't find one. Shouldn't be hard at all to get a rough starting point.
Go learn about tuning if you don't know what you need to do to the fuel and ignition maps in the boost region.
better yet, just truck the car to the tuner.
yeah im thinking of using the na one just to get it started and then get it tuned
what size injectors? I may have something suitable.
the adaptronics are shipped with a base map in them that should get just about anything started.
I got my 16v smallport with quads running on that map, though it was unbelievably rich!! But it was enough to drive it around the street and onto the trailer to take to the tuner. If i had been a bit closer to the tuner i would have actually been happy to drive it there.
And then a friend ran and started his highly modified 1jzte on the same tune. And he managed to do skids on it : P
So yeah just use the base tune to get it on the trailer and take it to the tuner.
Oh and if you look in the basic setup panel there is a drop down menu where you can choose the motor you are running. So you select 4age and it sets up the triggering and shit to suit your motor...hopefully![]()
err. thats not really recommended though. especially the skids part.![]()
haha nice, anthony im running stock ze injectors
yeah he is a bit silly![]()
I didn't drive mine further than onto the trailer cos I was worried it was going to wash the bore
