Results 1 to 6 of 6
Thread: still got smoke issues
    Nic
    Mt Evelyn
    Default still got smoke issues
    hey guys i had bad oil smoke a while ago and it was caused by the restrictive oil drain i had, i fixed that up but i have started getting some smoke again on the odd occasion mainly just when im at the lights or idling, only noticed it since the hot weather? dunno if thats the problem tho?
    was gonna ask if it could have something to do with when the turbo was burning oil??
    any ideas or things to eliminate would be great.
    Veteran shift_rook's Avatar
    SE Burbs
    well if the engine's been built to all the correct shit we can cross that off, turbo seal?
    Jay
    if you have noticed it since summer maybe its the oil you are using, what sort of weight is it?
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    yeah some manuafacturers recommend changing oil (thicker) when the temperature reaches above the 32 degree mark, i know nissan recommend this for there turbo motors
    PROTEK TYRE AND AUTO
    SQ ENGINEERING
    NCCE
    Nic
    Mt Evelyn
    its running 5w30 castrol synthetic. i might change to some 10w40 in a motul. do you think the motul turbolight is any good?
    Jay
    yea would defiantly change to something thinker , havnt used any motul oil but I am using 10w 50 Valvoline fully synthetic atm first oil change after rebuild and its running well
  1. smoke and idle problems?
    By nburr20 in forum Technical - Questions
    Last Post: 23rd September 2012, 05:16 PM
  2. Blue smoke... Not winfield :(
    By DR1FTER in forum Technical - Questions
    Last Post: 21st February 2012, 09:41 PM
  3. What brand of cigarettes do you smoke?
    By aaron_drift in forum Offtopic Discussions
    Last Post: 25th July 2008, 08:29 AM
  4. White Smoke
    By Pat_AE86 in forum Technical - Questions
    Last Post: 17th February 2007, 07:15 AM
