I know alot of discussion has been had, but im unsure if this issue has been raised. I want this setup to work cos itd make for alot neater solution. I drew a pic to try get the idea across, but basically it is a High pressure fuel pump (such as R31 skyline as is allegedly a good fit) inside a surge tank thats made a to fit over the pump and inside the pickup, and a lift pump connected to the surge tank mounted in the main tank.
Whats the concensus?
