i think i remember seeing a 20v with a ca18 one adapted to it ? was in japan though so no idea what work would be required
I'm searching high and low to try and find a crank angle sensor for my 4agze, had no luck. Does anyone know where to get new or one from another engine that would work??
Any help appreciated.
Jake.
I got nothing.
if you are using the cas with coils you should be able to modify a smallport dizzy to suit as they use the same CAS pickups as the gze, but they just have a cap and rotor on the top. do you have a GZE CAS at the moment and it's broken? cos you could probably swap some of the bits over between the two
i have a cas doesnt have origional plug on it but still works fine!!
AE86 THE BEST
Andy san: Going to turbo and really wanted to do away with the dizzy, and I don't have anything at the moment as I bought an engine with nothing bolted onto it.
Fast eddie: How much do you want for it?
Cheers guys,
Jake
I got nothing.
i donno pm me an offer
AE86 THE BEST
there is a guy on twincam.org selling one for $100
