Results 1 to 8 of 8
Thread: smallport with bigport parts
    mark
    central coast
    Default smallport with bigport parts
    Car - toyota sprinter
    motor - smallport
    use -
    problem - has bigport parts
    occurs/started when - plugs dont match loom
    ok i bought myself a smallport engine package. but being a noob i didnt realise till i went to install it, that a few of the parts on it were off a bigport. so i have bigport injectors and tps. can i use these if i change the plugs on the loom or will i need the correct parts
    Ok
    Seamus
    Milton
    use the correct TPS and injectors
    mark
    central coast
    thats what i thought. i guess its off to find some parts then. thanks mate
    john
    nsw
    liverpool
    what loom are you running ? JDM or smallport loom modified to suit rwd .
    Aaron
    In the Mountains
    bigport/smallport are slightly different sized injectors?
    id be using the correct parts rather then trying to do a short cut.
    Senior Member .ady's Avatar
    Andy
    Footscray
    or keep bigport stuff and get a big port loom
    mark
    central coast
    i have a bigport loom and a smallport loom. but i dont think the bigport loom and ecu work with a smallport dizzy
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Correct!
    You need all the electricals from one system, either all bigport gear or all smallport.
  1. Replies: 12
    Last Post: 27th July 2010, 03:44 PM
  2. Bigport or smallport?
    By dunga70 in forum Technical - Questions
    Last Post: 9th April 2010, 05:41 PM
  3. smallport bigport?
    By 86TRD in forum Technical - Questions
    Last Post: 30th July 2009, 04:00 PM
  4. Bigport / Smallport 4AGE Hybrid motor. ALL PARTS MUST GO
    By DavisJD in forum Car Parts For Sale
    Last Post: 7th May 2009, 08:50 AM
  5. bigport or smallport
    By Maxhag in forum Technical - Questions
    Last Post: 12th September 2007, 01:56 PM
