Results 1 to 6 of 6
Thread: ke55 wanna convert to hydrolic clutch IDEAS
    Senior Member ae86-13b's Avatar
    Troy
    Gisborn
    Default ke55 wanna convert to hydrolic clutch IDEAS
    GOT A KE55 putting sr20det in. any ideas on how to convert to hydrolic clutch thanks thanks guys
    It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
    Senior Member resol's Avatar
    steve
    vic
    well i doubt the ae71/86 /t-18 pedal box would fit but you could test fit and see how close it is. other wise you'd be looking at a custom pedal box mounted with a standard rolla clutch MC and custom line to a s13 slave cylinder.
    depending on cash and skills you can make one up yourself. pay someone to make one, or throw a tilton pedal box in
    but have a look on rolla club i know theres a few heavily modded ke's on that site.
    -dan
    gunner:
    ALL DRIFT MODIFICATIONS
    Ross
    For my KE30, my mechanic got a T18 Pedal box and used the clutch pedal off that. He got the KE30 pedal box, and got the exhaust guy next door to weld on the T18 clutch pedal attachment onto it.
    Than he used a holesaw to make a hole for the master cylinder and bobs your uncle.
    Worked a treat to, maybe a little low position wise, but thats just personal nag.
    EDIT: About the only problem with it I remember him having, was that he had to machine down the pushrod in the slave cylinder to get it working right, but that was about it.
    Cheers Fusion
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    have alook in my ke70 build thread i made the clutch pedal work backward inside the cabin of the car theres detailed pics in my thread!
    AE86 THE BEST
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Inside the car would be the go as there isn't a great deal of room around the engine with an SR if your placement isn't agreable..
    Senior Member spoon's Avatar
    Oatlands
    have a look at he celicas of that era - maybe their pedal box's are easier to adapt to fit... i know the 2tg's from celiacs are swapped into ke shells if i remember correctly they use hydraulic clutch setup from them as well - think ta22 etc.
  1. ae71 hydrolic clutch pedal box
    By maners in forum Cars or Parts Wanted
    Last Post: 15th May 2011, 05:28 PM
  2. Ke70 manual cable pedalbox.. NOT hydrolic!!
    By corey70 in forum Cars or Parts Wanted
    Last Post: 6th March 2010, 11:48 PM
  3. ke55 wanna convert to hidrolic clutch IDEAS
    By ae86-13b in forum Technical - Questions
    Last Post: 17th November 2009, 11:38 AM
  4. hydrolic handbrakes whats best?
    By pen15 in forum Technical - Questions
    Last Post: 5th October 2009, 06:05 PM
  5. ae71 hydrolic cluth into a ke70
    By DRF17 in forum Technical - Questions
    Last Post: 13th April 2008, 09:29 PM
