Results 171 to 180 of 743
Thread: Keemz's KE
Threaded View
    Nov 2009
    Eastern Suburbs
    Arrow the slow smurf
    ENGINE:
    • AE92 4age 16v Small Port MAP (rebuilt)
    • TRD Style Exhaust Manifold
    • Cut & Shut Inlet Manifold
    • TRD Twin Core Copper Radiator (custom mounts)
    • Custom RWD Cooling System
    • Trust Oil Cooler Kit (non-relocation)
    • 2ltr. Custom Surge Tank
    • Goss VL External Pump
    • VL lift pump
    • Few Speed Flow Fittings
    • K&N Pod Filter
    • 2¼” Straight Through Side Exit
    DRIVELINE:
    • T50 Gearbox (ADM)
    • One-Piece Braided Clutch Line
    • AE86 Gearbox Cross Member
    • AE71 Clutch Master & Slave Cylinder
    • TRD Lightweight Flywheel
    • Exedy Heavy Duty Clutch & Pressure Plate
    • Custom One-Piece Tailshft
    • Locked Standard Diff (Borgy)
    SUSPENSION / BRAKES:
    FRONT:
    • AJPS AE86 Coilovers 8kg 200mm
    • KYB Excel-g Short Strokes
    • AJPS Roll Center Adjusters 40mm
    • AJPS Lock Spacer
    • XT130 Corona Control Arms (fresh Super Pro bushes)
    • AE86 Power Steering Arms
    • AE86 Brakes (ADM)
    • TRW AE86 Brake Pads
    • Super Pro Steering Rack Bushes
    REAR:
    • AJPS 6KG 235mm Springs (cut to 200mm)
    • AJPS on Car Adjustable Panhard Rod
    • Stock Blown Shocks
    EXTERIOR:
    • Front & Rear Guards Rolled/Slightly Flared By Hand
    • Blacked Out Light Surrounds
    • Engine Bay Painted Pewter
    • Jap Plates
    INTERIOR:
    • Nardi
    • HKB Boss
    • Cheap Ball Gear Knob
    • Fully Striped
    • Floor Painted Gloss White
    • Fixed Bucket Seat
    • Fire Extinguisher
    • AE71 Pedal Box
    • Custom Dash
    • Speco Tacho
    • Speco Oil Pressure Gauge
    • Speco Oil Temperature Gauge
    • Speco Water Temperature Gauge
    • Speco Fuel Level Gauge
    • Custom Ignition Switch Panel
    • Battery Isolator Switch
    WHEELS:
    • Pair of SSR Longchamps XR4 15” x 7” -1
    • Pair of MA61 14” x 7” +8
    wen i went to look at it
  1. Replies: 5
    Last Post: 9th July 2011, 03:31 PM
  2. Keemz's S13
    By keimeier in forum Dirty Dattos
    Last Post: 26th November 2010, 05:28 PM
  3. KE 55 OR KE 30 Diff Required
    By uiz733 in forum Cars or Parts Wanted
    Last Post: 9th February 2010, 10:53 AM
  4. KE drum covers/rear mounting plate or Auto ke setup
    By bigm in forum Cars or Parts Wanted
    Last Post: 18th September 2008, 09:01 PM
  5. WTB - Locked KE center or ke diff assembly [QLD]
    Last Post: 22nd May 2008, 10:28 AM
