i had the same problem ages ago, i used a washer that was pretty hard. so all i did is got the a rubber washer beside me... slowly undid the sump bolt, then jammed my finger there. then i got my sister to change the washer and i put it back in.
you will either get your arm covered in oil (loose like 200ml) or you will have to drain it entirely.
